tender water level gauge
Post  Kevster on Sun 13 Nov 2011, 8:54 pm
Did I dream it or did someone mention that the new batch of 4" agriculturals are getting a water gauge of some description?
And if thats correct what does it look like and could it be fitted to the 4" dcc?
Any pics of it anywhere ?
Re: tender water level gauge
Post  bjwlancashire on Sun 13 Nov 2011, 10:32 pm
Kevin
It is a rod with a float on the bottom that protrudes through the floor of your tender I think, that or just a straight forward dipstick. Either way it is not on the Road loco but could easily be made to fit - just mind all that nice paintwork. I am sure you can buy the piece that fits to the tender floo from STW and make a rod to suit the depth of your tender. Alternatively, if you have access to a small lathe turn yourself up a stepped bush to fit into the floor with a hole through to suit the rod diameter of your choice.
Take a look at the photos that came on the CD, they do show a dipstick tube on both engines even though STW have not put one on.
President's man stand area - note the tube stickin up near the oil can, that would have a rod inserted as a dip sticl
Ex-Mayor's man stand area - there is a tube with a bolt head in it between the water pipe and the by-pass return pipe. That is probably a dipstick too. A bolt welded to a piece of round bar to stop it going all the way through - nothing technical here!!
Post  Kevster on Mon 14 Nov 2011, 6:01 pm
Thanks Brian,
I have a lathe so will turn something up, will be nice to know the water level at a glance when in steam.
Post  mikero on Tue 15 Nov 2011, 1:34 am
I made the float for my 3" engine out of packaging foam, I do wonder how well it will survive the boiler treatment though.
Number of posts : 257
Post  bjwlancashire on Tue 15 Nov 2011, 11:11 am
mikero wrote:I made the float for my 3" engine out of packaging foam, I do wonder how well it will survive the boiler treatment though.
I also wonder if it was made from the stuff on the back of the cart in your avatar, would it indeed be a "float" Shocked
Anniversary
Post  Steve Traill on Tue 22 Nov 2011, 8:23 am
A moments silence please ..................... as on this day in 1718 'Blackbeard' the English pirate was killed off the coast of Virginia USA. Crying or Very sad
Number of posts : 751
Post  bjwlancashire on Tue 22 Nov 2011, 10:14 pm
Steve Traill wrote:A moments silence please ..................... as on this day in 1718 'Blackbeard' the English pirate was killed off the coast of Virginia USA. Crying or Very sad
Avast landlubers, one day I will return to haunt you all affraid
