Eccentric rods
Eccentric rods
Post  Rickster on Fri 28 Oct 2011, 10:19 pm
Hi Craig/Steve,
I have only one straight eccentric rod. Please see attached picture. Not easy to show but the one to the right is the only straight one. The worst two are either side of the ruler.
Also missing 8 M6 nuts to secure the rods to the straps. It says 16 in the kit list but only 8 have been supplied in mine already attached to the straps, and no spares.
Awaiting your comments.
Lack of nuts
Post  lynnr on Sat 29 Oct 2011, 2:14 pm
Hi STW
I can confirm I am short the nuts for securing the Rods to the straps. One of my rods is also curved but not too bad. Unfortunately one of my rods at the expansion end both saddles are fractured.
Number of posts : 2981
Re: Eccentric rods
Post  Graeme81 on Sat 29 Oct 2011, 2:42 pm
sack the packer!!! lol!
Graeme81
Number of posts : 178
Re: Eccentric rods
Post  FosterGP6NHP on Sat 29 Oct 2011, 8:11 pm
That looks like they were machined out of bright drawn steel and the stock size was not big enough to have the rectangular rod section in the middle of the stock. Best to use black stock it does not bend from stress in the bar.
FosterGP6NHP
Number of posts : 12
Registration date : 2011-05-18
curved rods
Post  Steve Traill on Sat 29 Oct 2011, 11:55 pm
Just checked my four rods and three were somewhat curved just like yours Rick. With a steel rule as a straight edge & 5 minutes of careful bending they are all straight as a dye now, just don't bend too much the other way! The trick is to find were the high spot is as it's not always in the middle and then take that out. Two were just bowed but one was W shaped which took a little longer to suss out & straighten.
Number of posts : 738
Re: Eccentric rods
Post  Rickster on Sun 30 Oct 2011, 2:07 pm
Thanks for the advice Steve. Did you use any heat or just bend 'em cold ?
Mine two are bent/bowed at different points along their lengths.
Straightening rods
Post  Steve Traill on Sun 30 Oct 2011, 4:49 pm
Hi Rick
I just straightened them cold with hand pressure and the rod held in a 4" vice, it didn't really take much pressure as the amount of movement required is very small.
Re: Eccentric rods
Post  craig@STW on Tue 01 Nov 2011, 7:59 am
OK...
the bends in the rods are due to stress release in the bar when they are machined. this is normal and we would usually straighten them before they go out. however this seems to have been missed on this occasion. you can straighten them yourselves but if you feel you would rather we did it please return them to us.
i would only attempt minimal lapping on the eccentrics and straps. again if you are in any doubt send back both the strap and eccentric, and we will sort them out
if you are not happy with any of the parts, return them to us for replacement.
Mike will review the fastener quantities and send out any that are missing. we wont sack him this time but will give him a good kicking Twisted Evil
i apologise on behalf of the people responsible Embarassed
Number of posts : 1326
Re: Eccentric rods
Post  Rickster on Sun 06 Nov 2011, 11:20 am
Thanks for Steve Trails' advice - all rods now straight and taken to the platers.
I wished I had not bothered with the plating kit from Frost now. I took the whole motion bits - con rods, crossheads, all nuts, bolt, washers and all the valve gear compenents to a company in East Kent, who quoted me 50 to plate the lot with no polishing. They will polish the Eccentric rods and cross heads for an extra 15 and I'll have it all back within two weeks.
For anyone interested the company is Butterworths in Ramsgate. They are incredibly helpful and I would add I have no connetion with this buisness, they were recommended to me by an engineering company in the area.
As you can see not worth the cost of the FRost kit, so If anyone wants to buy a cheap Nickel plate (normal sheen), let me know. I have a heater, aquarium pump and a glass tank to take larger parts as well.
Re: Eccentric rods
Post  highpressure on Sun 06 Nov 2011, 5:11 pm
What are you looking for for the plating kit? and will the depth of the plate affect the crosshead gapping or have you not set the slides yet?? Also what about the bushes in the little ends??
Kev.
Plating
Post  Steve Traill on Sun 06 Nov 2011, 7:17 pm
When I plated the motion work on my 4" SC I found that the nickel plating is lazy in that it forms thickest on the parts nearest to the plates. Very little seemed to go into any holes but it did affect the clearance of the motion work on the outside of some of the rods so that one has to allow a bit more clearance and then (hopefully) when it's plated its a snug fit.
Plating
Post  Steel Steam on Thu 10 Nov 2011, 10:43 am
I bought a nickle plating kit from Frost when building my 4" Burrell. I ordered the "brush on" type so that I could plate the long parts. The results were very dissappointing and produced a brownish finish rather than a bright "silver" look. A few weeks later rust appeared and I gave up.
I then found a very helpful company in Portsmouth who in several batches plated most of my unpainted parts at an average cost of around a pound per item. I am very pleased with the results they achieved.
I trial fitted all parts and cleaned them up well before sending out for plating. When I mentioned the bushes I had already fitted to some of the motion parts the plating company fitted small rubber corks to them to keep the fluid out and prevent the insides becoming plated. The thickness of the plating is just a few microns so should not prevent parts fitting after plating. I certainly had no problems with fitting.
I would certainly recommend anyone to nickle plate unpainted parts and use a professional platers to get the best result in the least time.
Would anyone like a little used plating kit?
David Steel
Steel Steam
Number of posts : 20
Re: Eccentric rods
Post  highpressure on Thu 10 Nov 2011, 5:15 pm
Hi David,
Dont want the plating kit but could do with the details of the platers as I want to get my bits done soon. Hope you're doing OK.
Cheers Kev.
Re: Eccentric rods
Post  eng14110 on Thu 10 Nov 2011, 9:55 pm
highpressure wrote:Hi David,
Cheers Kev.
Hi Kev.
I'll do you bits for you got a couple of nice house bricks and a sharp stanley knife !!! Embarassed Embarassed Evil or Very Mad Evil or Very Mad
Colin
eng14110
Number of posts : 44
Re: Eccentric rods
Post  highpressure on Fri 11 Nov 2011, 4:40 pm
Hey Colin,
You'd need to find them and sew them back on first.. Shocked Shocked Dont forget I bought a bowser at the GDSF and SWMBO saw the credit card bill last week!!!!! Laughing Laughing
Hows your build coming on??
Kev.
Re: Eccentric rods
Post  bjwlancashire on Fri 11 Nov 2011, 8:23 pm
highpressure wrote:Hey Colin,
Kev.
Hey Kev
You should not have mentioned that, now the clock is ticking - you need to finsh it by next week to beat Lynn!! Razz
Re: Eccentric rods
