Motion drip tray.
Motion drip tray.
Post  lynnr on Fri 21 Oct 2011, 4:01 pm
Hi STW.
A few moons ago I inquired about the piston drip tray. The screws did not fit. Your response was the holes were tapped to large in the second batch casting. Is there any sign of the modifications as things are getting busy around where the tray should be and soon will be almost impossible to fit.
Number of posts : 2919
Re: Motion drip tray.
Post  craig@STW on Fri 21 Oct 2011, 5:29 pm
ooh yes, thanks for reminding us on this one. you were supposed to get some larger fasteners and open out the holes in the tray.
i guess this never happened then ???
sorry bout that, i'll get on to it Monday
Number of posts : 1277
Post  craig@STW on Mon 24 Oct 2011, 9:10 am
OK, just spoke to steve on this and it was decided to supply all the "M4" blocks with deeper drip trays.
the easy solution is to drill out the original holes to fit an M4 but with the trays being so shallow there is not much to play with.
the new ones are still to be made Neutral
Post  lynnr on Mon 24 Oct 2011, 9:31 am
Ok Doky.
As you can see from my photo thread things are progressing well. Waiting for the next kit now.
Post  lynnr on Wed 11 Jan 2012, 1:06 pm
Hi STW
Any ETD? on the revised drip trays.
Post  craig@STW on Wed 11 Jan 2012, 4:03 pm
in all honesty... no pale
not sure if Steve has had any thoughts on them but nothing has come down to the workshop yet.
thanks for the reminder Cool
Post  lynnr on Mon 23 Apr 2012, 8:34 am
craig@STW wrote:in all honesty... no pale
Gently prod again please.
