IanL Road Loco
Page 6 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Re: IanL Road Loco
Post  SSGR on Wed 26 Jun 2013, 9:57 am
Looking very smart Ian.
John
SSGR
Number of posts : 87
Re: IanL Road Loco
Post  IanL on Wed 26 Jun 2013, 2:31 pm
Brian, unfortunately I will not be bringing along my engine. I had intended on doing so but had cancelled attending because to my wife was supposedly having an op and now that is cancelled. I do not have a method of transporting the engine as I had stopped trying to sort the trailer ramps out.
See you Saturday
Re: IanL Road Loco
Post  IanL on Mon 23 Sep 2013, 6:34 pm
Well have had a few distractions during the summer, sons wedding, and mother in law unwell and eventually dying, but have done a bit now and again on the engine;
i also managed to get down to Dorset on the Saturday when it was a bit dusty, Brians road loco on the STW stand black it was not! although looking at the photos of my engine show it covered in dust and it has yet to get sun on its back!
Re: IanL Road Loco
Post  lynnr on Mon 23 Sep 2013, 10:21 pm
Hi ho.
Nice to see progress. I think the forum will let you off for the slow progress on the grounds of problematic life events.
I noticed your oilers. Got a suggestion. Before they get oily why not take all the lids off and knurl them to make them easier to screw on and off. I did mine by using one of the pots in the lathe and screwing each top on to it and hand turning agains the knurl tool. Makes life so much easier oiling up.
Number of posts : 2915
Re: IanL Road Loco
Post  IanL on Tue 24 Sep 2013, 8:14 am
Thanks for the suggestion on knurling the oiler lids, the one on the weighshaft tight against the governor pulley is a real challenge to open, not sure how I will achieve it as I do not have a lathe or knurling tool, will ask a couple of local guys if they can help.
Re: IanL Road Loco
Post  highpressure on Tue 24 Sep 2013, 4:54 pm
That oiler harndly uses any oil, I just squeeze the oil through the hole in the lid. It only supplies the weighshaft rod as it runs back and forth. A more useful mod would be to find a way of stopping the oild being flung out of the lid whilst running covering the engine in it and allowing the dust to stick to it. Dont know if Tims mod has been successful but I would think it must help.
Re: IanL Road Loco
Post  IanL on Mon 23 Dec 2013, 2:06 pm
Have now received all kits except for 30b the crankshaft arrived last week. So have had a bit of a go at getting that fitted and the HP con rod fitted
Here is the flywheel and eccentrics drying in the warm after painting.
Image :
Re: IanL Road Loco
Post  bjwlancashire on Mon 23 Dec 2013, 2:14 pm
No images Ian? That was tantalising.
Re: IanL Road Loco
Post  IanL on Mon 23 Dec 2013, 4:23 pm
Sorry Brian iPad not playing ball with the images
Re: IanL Road Loco
Post  IanL on Mon 23 Dec 2013, 5:05 pm
Re: IanL Road Loco
Post  IanL on Sun 02 Feb 2014, 4:19 pm
Have managed to do bit more painting and fitting and fidling with the engine over the last few weeks. so here are some pics from today.
Re: IanL Road Loco
Post  Robfishman on Sun 02 Feb 2014, 4:27 pm
Ian it looks great, love the blue and yellow.
Re: IanL Road Loco
Post  Tony King on Sun 02 Feb 2014, 5:03 pm
Another very nice engine coming together beautifully, well done Ian!!
Bet STW are delighted that so many of their engines are being built to such high standards!!
Re: IanL Road Loco
Post  SSGR on Sun 02 Feb 2014, 5:18 pm
Looks great Ian, I like the blue.
John
SSGR
Re: IanL Road Loco
Post  the coleman on Sun 02 Feb 2014, 8:31 pm
Looking good ian have got all your kits now.
Number of posts : 212
Re: IanL Road Loco
Post  IanL on Sun 02 Feb 2014, 9:04 pm
Yep now have all the kits the roof arrived last week, but several kits need to be fettled and fitted as I am well behind.
Re: IanL Road Loco
Post  Flasback on Sun 02 Feb 2014, 9:35 pm
Ian, I have not been on the forum for sometime its good to see the progress you and the others are making, next year should be a top season for STW with these engines and the Foden wagons being completed.
Flasback
Number of posts : 186
Re: IanL Road Loco
Post  bjwlancashire on Mon 03 Feb 2014, 2:14 pm
More shiny engines!!!! Nice work Ian, have you run it on air yet?
Re: IanL Road Loco
Post  IanL on Mon 03 Feb 2014, 2:41 pm
bjwlancashire wrote:More shiny engines!!!! Nice work Ian, have you run it on air yet?
Hi Brian,
Not run on air as yet still many holes to fill and not yet fitted the LP con rod. Plus need to make up the water gauge but slowly plugging the holes. I have turned it over by hand and no tight spots, but the water pump eccentric does not appear to be taking any oil so will need to look into that first.
Re: IanL Road Loco
Post  IanL on Fri 14 Feb 2014, 1:40 pm
have fitted the blower and lifter pipes, the lift hose connection as supplied does make the hose stick out. I will have to look into making up a 90 bend connector.
Re: IanL Road Loco
Post  lynnr on Fri 14 Feb 2014, 1:55 pm
Progressing well.
Tony and myself did 90 bends using standard pipe fittings with the threads filled off.
Re: IanL Road Loco
Post  bjwlancashire on Fri 14 Feb 2014, 8:30 pm
I also did the bend, standard plumbing Yorkshire fitting and cut the STW hose connector so you use both ends with the bend in the middle. Not sure if Tim and/or Tony described it but it makes such a difference.
Re: IanL Road Loco
Post  highpressure on Sat 15 Feb 2014, 8:07 am
Did the same too, as has Andy. Standard 90 deg elbow with the thread filed off and then I used a 10mm pipe union soldered inside the bend and cut the original fitting in half and set both ends on the copper pipe union.
Re: IanL Road Loco
Post  IanL on Sat 15 Feb 2014, 5:41 pm
Hi thanks for the suggestions on how you did the 90 bend I really will have to try and do this, as the pipe does not look good sticking out as it is.
Re: IanL Road Loco
Post  IanL on Mon 24 Mar 2014, 6:42 pm
Had ago at building the oiler
And painted the cylinder name plates
Re: IanL Road Loco
