Belly Tank Hornplate Bracket
Post  Garity on Sun 21 Aug 2011, 10:47 pm
I'm completing the belly tank for my Road Loco and want to ensure I've got the proper Hornplate Brackets before I paint. They are replacement parts BS41768. Is this the latest configuration? Please advise. Thanks.
Garity
Number of posts : 3
Registration date : 2009-10-01
Tank brackets
Post  Tony King on Mon 22 Aug 2011, 7:20 am
The latest tank brackets have an extra line of holes for "dummy bolts". ie, they have 20 holes in each of them.
Hope this helps.
Re: Belly Tank Hornplate Bracket
Post  highpressure on Mon 22 Aug 2011, 9:40 am
And the double row of holes go onto the hornplates to push the tank out further. You woudln't want to put these the wrong way round and paint it to find they need to come off!!!!
Belly tank latest brackets
Post  lynnr on Mon 22 Aug 2011, 12:50 pm
Have a look at my photo thread and the latest pictures you can see the latest version of the brackets. Unpainted currently as I am waiting for the list of parts to be sprayed black to grow a bit as it makes spraying more efficient as less waste.
Number of posts : 2915
BELLY TANK HORNPLATE BRACKET
Post  Garity on Wed 09 Nov 2011, 2:14 am
The bracket has more holes than the belly tank. It seems the objective of the latest bracket is to move the belly tank away from the boiler. Please confirm that the belly tank needs another hole on the mounting face near top of the tank. Thanks.
Garity
Number of posts : 3
Post  craig@STW on Wed 09 Nov 2011, 8:01 am
yeah, there should be a note about this in the instructions.
we did have to move the tank down to provide clearance. this hole should be plugged up with a "dummy" bolt/bolt head Cool
Number of posts : 1256
