Finesse Lining Tape
Finesse Lining Tape
Post  the coleman on Mon 27 Jun 2011, 6:07 pm
just started road loco i'e front wheels and need some advise on which tapes sizes to do the all the lining. plus what are the best brushes to use.
thanks andy
Number of posts : 214
Re: Finesse Lining Tape
Post  sonick45 on Mon 27 Jun 2011, 6:24 pm
what style of lining are you going to do?
Number of posts : 489
Post  sonick45 on Mon 27 Jun 2011, 6:28 pm
Andy,
PM me your email and i'll send you some info re burrell lining widths.
I have them saved as jpeg scans so it's easier to email them.
Post  the coleman on Mon 27 Jun 2011, 6:46 pm
front wheels thinking about large black centre with fine yellow chrome either side
Post  Kevster on Mon 27 Jun 2011, 8:44 pm
can the finesse tape be brought round to do the fish tails easily?
I have been fussing over the style and how to do the lining for a while now, just cant make up my mind.
Post  the coleman on Mon 27 Jun 2011, 9:59 pm
not sure as i have'nt bought any yet. Im still working out sizes
Post  sonick45 on Mon 27 Jun 2011, 10:08 pm
Kevster wrote:can the finesse tape be brought round to do the fish tails easily?
You might struggle with it but it's not impossible..
I didn't use this technique on my fish tails as i found it wasn't consistent enough. In other words non of the few fish tails i tried with tape looked the same which in scale looks naff.
Post  highpressure on Mon 27 Jun 2011, 10:11 pm
With practice and great patience it is possible to "pull" the tape into fish tales but due to the fact that each one is done individually there is a slight degree of variation. However on my wheels I dont feel it is that noticable but a perfectionist or rivet counter may pick it up. There is also the method of using compass blades to cut consistent curves in clear masking tape which Sonic knows more about.
Spoke lining
Post  lynnr on Tue 28 Jun 2011, 3:35 pm
I done the centre yellow on mine with the tape from UKpinstriping. Then used the beugler to do the red edges. Also doing this made the yellow perfectly centre and the reds even.
Number of posts : 2974
Post  the coleman on Tue 28 Jun 2011, 6:43 pm
[quote="lynnr"]Hi
what size tape's did you use from UK pinstriping, Did you do both sides of the spokes and how much did you use
Tapes
Post  lynnr on Wed 29 Jun 2011, 6:09 pm
Think it was the F12 3.17MM 4.76MM 3.17MM tape I used for the spokes. Then lined with the beugler middle one of the standard set.
I done both front and rear in this method. Creating the tails of the red by following the spoke flute round the edge of the spoke. At the hub end I put strips of tape at 90deg to the spoke to create a start and finish point.
