Water pump yes or no
Post  hughb on Tue 14 Jun 2011, 9:56 pm
Well soon I hope to put back my engine Very Happy Mad But I was thinking with the injector.
Is it worth fitting a water pump insted Question As it will not work to well on warm water.
Or making a by pass just in front of the injector.
What do you guys think??
Re: Water pump yes or no
Post  chrisnchrisroberts on Tue 14 Jun 2011, 11:08 pm
Put the pump in the tank and no one will know, unless you tell them. Chris
chrisnchrisroberts
Number of posts : 123
Post  wattsg3 on Wed 15 Jun 2011, 10:15 am
Just remember you will need 2 totally independent means of getting water into the boiler to get a steam test certificate. Don't try and hide things out of the way
wattsg3
Number of posts : 3
Post  hughb on Thu 16 Jun 2011, 10:16 pm
wattsg3 wrote:Just remember you will need 2 totally independent means of getting water into the boiler to get a steam test certificate. Don't try and hide things out of the way
Hi yes this has been said by my mate he dose the tests .And yes it no good in anyway it is no .
We were thinking of in the back of the tender insted of the injector as it will not pump warm water .
Post  chrisnchrisroberts on Tue 21 Jun 2011, 11:20 pm
The idea to hide the pump was not to hide it from those who have to know about it. The suggestion to hide it was to stop the "Politically Correct Brigade" from tut tuting about having a pump. If you already have 2 systems for getting water into the boiler as per the regulations, then adding a pump would be 3 systems.
chrisnchrisroberts
Post  hughb on Fri 24 Jun 2011, 10:28 pm
chrisnchrisroberts wrote:The idea to hide the pump was not to hide it from those who have to know about it. The suggestion to hide it was to stop the "Politically Correct Brigade" from tut tuting about having a pump. If you already have 2 systems for getting water into the boiler as per the regulations, then adding a pump would be 3 systems.
Hi Yes not thort of this good ider .As for themwho know it all {have they made one Pluss It is mine Exclamation }
Thaks for the INFO Idea
Water pumps (hand)
Post  Frostie on Sat 09 Jul 2011, 10:43 am
I have fitted a hand pump on mine which is T'd into the waterpump outlet (took the elbow off and fitted a T piece) the pump is mounted in the tender on the tender water cover plate so that I can easily remove it if neccesary.
When I did my steam test, a nut leaked in the injector pipe rendering the injector U/s until it was sorted, but luckily I still had the hand pump as the second method of getting water into the boiler and passed the test. (the injector pipe nut has since been replaced)
Malcolm
Frostie
Number of posts : 145
Post  Big Al on Tue 12 Jul 2011, 7:20 am
Frostie
Did you put a non return valve between the pump and T piece?
Pictures would be good
Big Al
Big Al
Number of posts : 147
Post  hughb on Fri 05 Aug 2011, 10:21 pm
Sorry but been off line at the mo Evil or Very Mad .I have put the pump in the back of the tender.
The pipe is going out the r/h side and will fit to the pipe that gose up at the angle .
With non return valve on it as well Exclamation .But the only snag at the mo is still in bits Wink Embarassed .
I will be down there in the morning and I hope all day. Laughing
hugh
