Name plates
Name plates
Post  lynnr on Tue 07 Jun 2011, 2:35 pm
Hi STW
Are you producing name plates and or engine number as I can remember some place in the forum you mentioned about the possibly of choosing the engine number but can not remember where.
Also I see on pictures that most engines have a plate on the rear spec plate stating the boiler should be washed out every 14 days etc. Are you producing this?
Number of posts : 2957
Re: Name plates
Post  sonick45 on Tue 07 Jun 2011, 4:41 pm
If STW don't offer these services then the following may help you.
You can get the washout plate from here : http://www.livesteammodels.co.uk/pdf/MES2011e.pdf
You will be able to get a name plate made up from here : http://www.loco-nameplates.com
Number of posts : 480
Re: Name plates
Post  hughb on Tue 07 Jun 2011, 10:06 pm
This is the place were I got mine done .Veary good http://www.loco-nameplates.com
Re: Name plates
