2inch scale burrell oil
Page 1 of 1 • Share •
hi,
just wondering what oil people with 2 inch scale engines are using in the oil pump to the cylinder? due to size i am wondering if cylinder oil is used or regular engine oil?
thx
thx
Graeme81- Number of posts : 178
Re: 2inch scale burrell oil
I've always used steam oil on 2" engines. I also use it on my 1" minnie.
regards
Andy
regards
Andy
andyc- Number of posts : 43
Although not a 2" owner I certainly would advise against using engine oil, steam oil is designed to mix with the steam and atomise into it, which engine oil wouldn't- this is some of the techincal details on Morris Steam Oil
"Morris Steam Cylinder oil 680 - Compound Steam Cylinder Oils 680, are for use in most Locomotives and Stationary engines working with either saturated or superheated steam.
They are produced from special cylinder stock treated with fatty compounds to provide superior lubrication even if wet conditions are encountered. The fatty compounds form emulsions which spread the oil on the internal surfaces, providing a strong lubricating film where needed to protect bores and valves. This is particularly important where very wet steam has to be handled at the cylinders, or water treatment chemicals are carried with the steam.
ISO 680 is for use with saturated & light super heat steam upto 250psi.
In addition to cylinders, these oils are recommended for valve chests, slides, linkages and general lubrication, by means of mechanical applicators, atomisers or oil can."
MrStationHouse- Number of posts : 313
Ello Graeme,
Have a word with Monsieur Steve n see if he's any steam oil floating about. But generally yup, use steam oil, normal engine oil will emulsify (snot up like mayo) once the water hits it.
It's as thick as treacle and lasts quite some time
LilyJack- Number of posts : 236
thanks lads for replies -reason i asked is i have absolutely no experience with steam engines of this scale (unless you count a wilesco!!) and i may be steaming one that has been left sitting for nearly 20 years, this weekend ! A thetford town 2 inch...
andyc wrote:Hi,
regards
Andy
Same as me
hughb- Number of posts : 575
» 6" scale Burrell Devonshire SCC
» 6" Burrell Single...Road Loco...Showmans?
» New Products
» Showmans / Road loco rolling chassis
» Lining the Burrell
» New Products
Page 1 of 1
