Ash pan clearance
Ash pan clearance
Post  Rickster on Fri 22 Apr 2011, 9:21 pm
Does anyone know if it's ok to have an air gap between the ash pan and foundation ring?
On my engine, to fully close the damper plate, I have to let the ash pan down to its maximum adjustment, which then leaves an air gap of about 5mm all round the foundation ring.
I think the damper flap is interfering with the foundation ring but am reluctant to file away any material off the damper plate until I know.
thanks
Ashpan
Post  Steve Traill on Fri 22 Apr 2011, 10:17 pm
To keep good control of your fire one needs a reasonably good seal between the ashpan and the bottom of the boiler. The whole point of having an adjustable damper is to be able to control the air flow to the fire (basically more air more fire). If air is leaking in all around the ashpan the damper becomes redundant. I would try and get it within a millimeter.
Number of posts : 717
Re: Ash pan clearance
Post  Tim Watson on Fri 22 Apr 2011, 10:34 pm
Fully agree with Steve. The ashpan on my TE does not seal that well and so it's difficult to quieten down the fire sometimes.
The design of the ashpan looks excellent, with only one set of pillars in the way when raking out the ashes.
Number of posts : 559
Post  Rickster on Sat 23 Apr 2011, 9:19 pm
Thanks for the advice guys - spent a fair few hours trying to get it all to fit.
I had to bend the damper plate further back and chamfer the back edge as it was fouling the bottom of the firebox.
I also found it best to loosely fit the fire bar supports to give a bit of movement when lining it all up then fully tightened them as the last operation.
I have a very small gap at the front, probably less than 1mm now, so I'm relatively happy with that now.
Another question - what do people use when it saysS in the instructions "thread sealant" when putting studs into the boiler ?
On the belly tank brackets, I cut off the top hole on the face part of where the bracket attaches to the belly tank as my nuts are on the outside.
Great advice Steve - I cut round the brackets and the threads, the POR 15 held the bolts no problem. I will just go round with POR15 and a paint brush again though when it's all completed just to be on the safe side.
Post  Tim Watson on Sun 24 Apr 2011, 7:39 am
My experience with the loose fire bars type of grate is that they should be a very sloppy fit in the slots, and kept loose in service, by chipping off any scale that accumulates. That way they can move when hot and don't distort with the heat, mine are now on their third season. Much better than cast grates.
Post  greystones on Sun 24 Apr 2011, 10:52 am
Have you all got the 2 spacers which go between the damper hinge and the flap or is it just that they were not in my kit.
If its just my kit will give Isabell ring.
Thanks Mike
greystones
Number of posts : 65
Parts missing
Post  lynnr on Sun 24 Apr 2011, 7:15 pm
greystones wrote:Hi
Thanks Mike
Your not alone. I am also missing them and contacted Craig on Friday.
Number of posts : 2950
Post  craig@STW on Sun 24 Apr 2011, 9:03 pm
yeah, i'll look into this on Tuesday, seems they may have been missed Embarassed
Number of posts : 1290
Post  craig@STW on Tue 26 Apr 2011, 8:27 am
OK, not all the spacers were missed as we are down on quantity, but some may have been. please check again and let me know by PM and we will send them out.
also the bolt for the for door handle was supplied with kit 16 (M5x10 hex).
Post  craig@STW on Tue 26 Apr 2011, 5:50 pm
yep, seems quite a few people are missing the spacers. PM me or give Isabel a ring/e-mail and we will get them sent out very soon Cool
sorry about that Embarassed
Post  bjwlancashire on Thu 28 Apr 2011, 12:46 am
Rickster wrote:Does anyone know if it's ok to have an air gap between the ash pan and foundation ring?
To reinforce the point from Steve Trail, I have seen a number of full size engines with some form of heat resistant material sealing the ashpan to the foundation ring. I am not sure what it was but I will try and remember to ask next time I see it unless someone else has spotted it and knows.
Maybe the likes of Seddon & Black or Heritage Steam Supplies (usual disclaimers Laughing ) have this material in stock. I know it is vital to have this sealed as well as possible otherwise you will have a roaring fire even when you don't need it. I know from experience as the Steam Yachts have a leaky ashpan and with the tall chimney on this ride it does pull the fire rather well even when the damper is closed.
Sealing the ash pan
Post  Steve Traill on Thu 28 Apr 2011, 10:51 am
I think the stuff you may have seen is what they use on woodburning stoves to seal the door. It's a sort of heat proof braided rope, I used to fit it to my woodburner many years ago. High modulus silicone was pretty good at attaching it as it is heat proof to about 500-600 degrees c. I used to have the woodburner white hot inside sometimes and I only had to replace it every 4 -5 years. It comes in a variety of thicknesses
Post  greystones on Sat 30 Apr 2011, 3:18 pm
Having recieved my spacers today I decided to fit the firebox.
I also have the same problem as others, in that it does not fit up tight to the foundation ring and the flap will not open properly.
On examination of my boiler the 4 corners of the foundation ring where the welds end, have NOT been ground off, this leaving a 2.5mm
protrusion of weld whch holds the firebox off the foundation ring. If these were not there the ashpan would fit perfectly.
Question for Steve... can I grind these off ? or would a boiler inspecter not take kindly to me doing this in the future. OR Should I cut a piece off the air flap which is what they butt up to.
It looks as if this is the same as Rick had on his.
Hope this helps others Mike
Last edited by greystones on Sat 30 Apr 2011, 3:21 pm; edited 1 time in total (Reason for editing : missed a bit)
greystones
Post  Rickster on Tue 03 May 2011, 6:58 pm
Hi Steve/Craig,
Any view on Mike's thread ? Can we grind the weld back safely ?
Post  craig@STW on Wed 04 May 2011, 1:58 pm
I think Steve "will" be commenting on this in some way, maybe by PM.
anyone who wants the quick answer can PM me Cool
Post  eng14110 on Wed 04 May 2011, 3:41 pm
Hi Rick,
I would not recommend that you grind the welds on your boiler. It could be classed as a modification, and as such could invalidate any pressure test carried out on it.
Colin
Rickster wrote:Hi Steve/Craig,
eng14110
Number of posts : 44
