Crankshaft Alignment
Post  chop on Sun 10 Apr 2011, 6:12 pm
Been struggling to align my crankshaft. Had to use lots of adjustment. Till I noticed that the front spec plate large hole for oil pipe (I think ?) did not line up. Took it out and took all adjustment off, did everything up tight and guess what ? perfect. So if you're struggling check front speck plate hole lines up. Had to shave spec plate so hole lined up and didn't push horn plate over. cheers
Number of posts : 77
