Chimney extensions and improving efficiency
Post  lynnr on Fri 01 Apr 2011, 11:28 am
By using a extension to the chimney do you think we could produce more electricity from the Showman engines?
http://vortexengine.ca/index.shtml
Number of posts : 2907
Chimney extensions
Post  Steve Traill on Fri 01 Apr 2011, 1:25 pm
Using a chimney extension helps to draw the fire especially in the early stages that is why on the 4" SC Burrell one is supplied. It also gives a natural draw as opposed to sticking an electric fan on top of the chimney which is prone to forcing air up through the fire.
The Showmans engines carried a chimney extension on the roof not to help draw the fire but to raise the smoke from the engine high enough so that it doesn't smoke everyone out at the showground. The secondary effect is to help the fire draw but it didn't really need it just for that. The amount of electricity generated is down to how hard the engine works and how well set up it is. Regarding engine efficiency the chimney extension wouldn't really help as that is more to do with extracting as much power from a given amount of steam as possible. So in answer to your question..............No!
Number of posts : 694
1st April
Post  lynnr on Fri 01 Apr 2011, 1:59 pm
Well do did not get it! rabbit
vortex
Post  Tony King on Fri 01 Apr 2011, 4:07 pm
I think a showmans will draw enough of a crowd without having a tornado coming out of its chimney!!
Re: Chimney extensions and improving efficiency
Post  hughb on Mon 18 Apr 2011, 4:31 pm
I only have a 2" I did make a taller chimney for but all the guys say no not needed
