Spray booth
Spray booth
Post  hudmut on Wed 30 Mar - 20:54:57
I was hoping you lot would give a bit of a in site to a little idea iv had. My workshop at home and work See's a lot of movement so trying to paint any thing with out it looking like its full of sand and other bits is hard. So i was going to get a 2m x 2m gazebo and make my self a bit of a spry booth has any one else done this is so any tips.
Was thinking along the line's of sealing it up with plastic but use Velcro to hold it all up so it pulls down quick if its in way. The next thing im really not sure on was about putting a fan in there with some form of filter what do you think ?
hudmut
Number of posts : 74
Spray booth
Post  chop on Wed 30 Mar - 21:05:12
I Bought a 5ft x 5th poly green house off eBay. Put a 6" fan in the roof with pipe to outside. Then got some wadding off the mrs and made to plywood frames which screw through the poly and clamp the wadding to act as a filter. Old bed sheet at the bottom for a floor which I soak with water to keep the dust down. before I spray works quite well. Considering I do a fair bit of woodwork in my shed
chop
Number of posts : 77
Re: Spray booth
Post  hudmut on Wed 30 Mar - 21:22:02
Well thats made me fill better nowing that some one else has done the same.
Ill got for it then and see how it works out
hudmut
Spray booth
Post  lynnr on Thu 31 Mar - 8:03:52
If you catch the series Street Custom Berlin. Where West Coast Customs set a shop up in Berlin they use a plastic sheet over the car lift as a temp booth. So if the pro's do it why not us.
Number of posts : 2906
Re: Spray booth
Post  hudmut on Fri 1 Apr - 22:42:45
Well i orded some timber to day got a fan of a mate in the aircon trade as well as a filter box going to buid my self some thing in the corner of the work shop and see how it goes.
I did see that on the westcost show one think i would say about them them must get thought some MDF they make every thing out of it
hudmut
Re: Spray booth
