Filler plugs
Filler plugs
Post  highpressure on Fri 18 Mar 2011, 4:52 pm
Am I right in thinking neither of the drain plugs for the tender and belly tank have been supplied yet? I presume they will come in the water fittings kit.
Re: Filler plugs
Post  eng14110 on Fri 18 Mar 2011, 8:20 pm
highpressure wrote:Am I right in thinking neither of the drain plugs for the tender and belly tank have been supplied yet? I presume they will come in the water fittings kit.
Don't forget the plugs for the boiler as well !!!
eng14110
Number of posts : 44
Re: Filler plugs
Post  highpressure on Fri 18 Mar 2011, 10:05 pm
I was looking to try and check that they are water tight after fiitting all the bits in and coating with gunge.
Re: Filler plugs
