Kit 14 boiler bits
Kit 14 boiler bits
Post  Rickster on Fri 11 Mar 2011, 10:22 pm
HI Steve/Dean,
The firebox doors arrived today, there is a part number BU41449 - Firedoor top runner pin x 2 inc fastensers. This is on the packing list but not on the Isometric and everythings gone together as it should without these parts. Do you want them sent back ?
Also you mention in the instructions we can put the belly tank on, but I still don't have the bracket to attach the tank to the boiler. Is this on it's way or an oversight waiting to be sent with a later kit ?
Re: Kit 14 boiler bits
Post  Rickster on Sun 13 Mar 2011, 6:20 pm
Forgot to mention when fitting the tender to the hornplates, I noticed the two bolts that exit by the oil boxes on the back axle, if not trimmed back push into the oil box sides on my engine, so just beware. It's the two bottom bolts by the curved section of the tender straps. It's not by much, just a few MM's but it did push the sides in making the lid difficult to fit.
