Boiler Painting.
Boiler Painting.
Post  zzr prid on Fri 04 Feb 2011, 1:29 pm
Picked my boiler up today Very Happy Very Happy , it looks very nice so a big thank you to all at steam traction world.
So its time to paint, what would the best paint to use / best way to paint the boiler ?
Do i need to use special primer and a high temp paint ?
Question Question
Thanks for all the help
zzr prid
Number of posts : 32
Re: Boiler Painting.
Post  Vapor on Fri 04 Feb 2011, 1:33 pm
I used high temp BBQ paint from B&Q with no primer as directed on the tin. it dry's with a silk sheen.
Post  hughb on Tue 08 Feb 2011, 11:06 pm
Hi As for me I used revves smokebox paint sprayed from gun. It is mat
Post  Steam Traction World on Wed 09 Feb 2011, 8:27 am
The 2" copper boiler is probably best left unpainted. If you do choose to paint it a high temperature paint is not necessary as the temperature of the boiler should only reach about 160 degrees centigrade. You will however need some sort of etch primer to enable it to stick and therefore will need to check what temperature the etch primer can withstand.
Number of posts : 902
Post  zzr prid on Fri 11 Feb 2011, 8:29 pm
Steam Traction World wrote:Hi,
Thanks for the help.
I was only planning to paint the fire box part of the boiler.
Do i need to use an etch primer and high temp paint for tha fire box ?
Prid
zzr prid
Post  LilyJack on Sat 12 Feb 2011, 8:20 am
Bonjour ZZR,
Thought I'd stick me two pennies worth in. I used stackpipe stove enamel, can be applied directly to metals and obviously its high temp (high enough for our engines anyway) Has stuck like s^^^ to a blanket with me n leaves a high black gloss shine. Be warned though, you have the SLIGHTEST drop of oil/grease anywhere and it'll cock it up, obviously that goes with any painting but it really does bugger this stuff up.
LilyJack Cool
ps: it comes in a hairysole can so it's easy to apply as well..
Post  hughb on Thu 17 Feb 2011, 9:31 pm
LilyJack wrote:Bonjour ZZR,
LilyJack Cool
HI beer man drunken drunken
I tryed this and it went all clowdy and bloomed .Maybe that is what it was ..????
