Beugler striper
Page 1 of 1 • Share •
Beugler striper
Can anyone tell me if they own or have a beugler striper wheel ???
I am looking to buy one to do the lining on my engine, but have never usd one before.
Are they worth the investment ?? Are they easy to use, and do they do a good job ???
I would be grateful for any info on thses units in able to make up my mind whether to buy one or not.
Cheers guys
Malcolm
Cheers guys
Malcolm
Frostie- Number of posts: 117
Registration date: 2010-09-10
To Beugler or not
Hi Malcolm
I have a beugler and it does make things very easy as long as you use it correctly.
You need to use the correct consistency of paint. I use the American 1shot lettering enamel.
You want to use a "turkey" baister to fill the Beugler as this reduces the waste.
There is occasions it does not work to well or require planning in how it goes. Landing and exit spots protected by masking tape etc.
lynnr- Number of posts: 1054
Registration date: 2010-08-06
Beugler wheel
Thanks Lyn, it looks like I will make the investment in one (£125 for the kit I had in mind)
Where do you get your paint from ??
Malcolm
Malcolm
Supplies
http://www.pinstripinguk.com/
The paint is expensive but very good. It is a heavy weight paint and will cover all but the brightest base coat in one coat even with primrose yellow. Also you want to get a tin of the "reducer" as it helps the paint dry quicker and is used as a thinner if you want to use a brush.
I have also used the masking tapes. The Scotch® 471 Series BLUE Plastic Fine Line Tape. Gives razer sharp edges, easy to mold round corners and trims very neat.
And
I use the finesse pinstriping multi tapes as well for parallel lining in different colours.
And
Buegler liner
Brilliant, thanks Lyn.
Malcolm
Malcolm
Re: Beugler striper
I have a Beugler but found it too fiddly with a 2" model, it wouldn't reach in the small corners and ended up using pinstripping tape and one shot paint, easier and cheaper!
Al
Al
Big Al- Number of posts: 142
Registration date: 2008-06-18
Buegler wheels
Thanks for that Al, what paint are you calling "one shot " ?? my first attempt at lining was a disaster, I had to sand down the cladding and re paint the darned things, they are now hardening off until I get back home for my next attempt at lining, I am not looking forward to doing it !!
Malcolm
Malcolm
Re: Beugler striper
Well I have one but it took me a long time to get the hang of it .
I bet if I was to use it now I could not do so good.
I used a sringe to fill it not I worn you not not snease if you can help it .
Good luck and pratice
hughb- Number of posts: 575
Registration date: 2009-03-13
Confidence
Also if you are timid with it it gets messy.
Be positive and bold as this produces better results.
Beugler wheel
Hi Lyn & Guys
I have just ordered the one shot paints and reducer as you recomended, I have also ordered some stencil tapes and a special brush, I should have all of thegear by the time I get back, I just need thhe bottle to do the job now LOL..
Malcolm
Malcolm
Good place to practice
Frostie wrote:Hi Lyn & Guys
Malcolm
As a suggestion for practicing. Gloss photo paper acts very much like a painted surface and is easy to practice on. I do that before committing to the engine.
Re: Beugler striper
Been reading this all it is now is GOOD LUCK and do tell how you get on
beugler wheels
Cheers Hugh,
I have now got a Beugler wheel, a special pinstriping brush, all the special paints, finesse pinstripe stencil tapes etc etc etc. It just need the application of my crappy paint skills now !!!!!! I will do as Lynn says, and practise plenty on glossy paper cos the paint job on the rest of the machine is coming on beautifully, and I dont want to bugger it up again.. (Crimson lake)
"Rosie " is coming along in leaps and bounds now, I willl get some pictures online when I get home and get the boiler cladding lined and fitted, then its all pretty straight forward to completion for the spring.
I am still waiting for a triple cock wayer gauge , if I don't get it by the time I come home early Feb, I will just fit the STW glass as I want to get on. I am also very tempted to fit a hand pump as a back up, Tee'd into one of the existing water feed pipes.
Have a good day
Malcolm
Have a good day
Malcolm
Re: Beugler striper
Malcolm
Just in case you were thinking of doing it, dont fit the hornplates to the boiler untill you get the new water gauge assembly! It will all have to come apart again to fit it and I hate to hear a grown man cry!
If you fit the hand pump I would be very intertested in seeing how it looks as I haven't got around to fitting mine yet. I was thinking of putting it in the coal storage area amongst the coal and T ing it behind the nearside gear guards but haven't got any further than the thinking stage yet.
Alan
Alan
Similar topics» Beugler striper
» Beugler Pinstriper Kit for sale
» Beugler lining tool for sale
» BEUGLER pinstripe system
» Blue Striper R-390As Gotta Love'em
Page 1 of 1
