Front tires
Front tires
Post  Alex-Jan on Thu 23 Dec 2010, 12:27 am
I pick up the method with the flowerpot from the 4”dcc part of this forum- see” front tires the easy way”- and this work out so well that I would recommend it to every one. Take 5 min to put the rubber around the rim. As Isoflex is not available in the Netherlands I use Sikaflex which is a rubber compound in a tube. I used this before in commercial jobs and now is will be a strong rubber if it is hardened.
I put some photo’s on http://www.miniatuurstoom.nl/index.php?option=com_joomgallery&func=viewcategory&catid=32&startpage=2&Itemid=36#category
Alex-Jan
Alex-Jan
Number of posts : 44
Registration date : 2010-10-26
View user profile http://www.miniatuurstoom.nl
Re: Front tires
Post  hughb on Fri 24 Dec 2010, 4:35 pm
AS for me I only built a 2" engine. Cool Laughing The tyers for me were mad AS I pulled them on
they just poped off by undoing the joint . Twisted Evil +In the end they were only done by
STW .............Well do I like the flower pot .I would never think of it Idea . Embarassed
Good luck and keep going Shocked
