Drive pin fit in rear wheels on 2" Burrell
Post  Dave Saunders on Tue 02 Nov 2010, 1:30 pm
Thought I'd try the drive pin in the rear wheel hubs, to make sure the caps didn't foul. The holes through the hubs are undersize, probably about .005". I can run an 8.0mm h7 reamer through them, but I don't know what sort of fit required.
On a different topic I am considering baking the smokebox bits (Firecote VHT), but wondered whether the fumes (assuming there are some), would affect the oven. Of course I could buy a cheap mini oven, but wondered if anyone else had done this!
Dave Saunders
Dave Saunders
Number of posts : 6
Registration date : 2010-10-27
Oven baking
Post  lynnr on Tue 02 Nov 2010, 1:50 pm
I have used VHT paint on my smokebox and baked in oven at 200 for 2 hours. Then cooled oven to 170 and then cooked dinner with just holding the door open for a minute while taking the smokebox out. No smell and no taint of flavour.
Number of posts : 2950
Re: Drive pin fit in rear wheels on 2" Burrell
Post  craig@STW on Tue 02 Nov 2010, 3:20 pm
hello Dave.
the pins just need to be a nice push fit. the retaining plate should keep them in place
Number of posts : 1290
drive pins
Post  Dave Saunders on Tue 02 Nov 2010, 4:34 pm
Thanks for the prompt response. Reaming it with an h7 reamer would give me a snug slide, with no perceptible play, or do I need it to be a slight intrference i.e. tapped in?
Dave
Dave Saunders
Number of posts : 6
Smokin'
Post  Dave Saunders on Tue 02 Nov 2010, 5:04 pm
lynnr wrote:Hi
Thanks Lynn, I'll give it a go, once I've shown your resonse to Management!!!
Dave
Dave Saunders
Number of posts : 6
Post  craig@STW on Tue 02 Nov 2010, 5:45 pm
Dave Saunders wrote:Thanks for the prompt response. Reaming it with an h7 reamer would give me a snug slide, with no perceptible play...
im sure this would be fine Cool
i normally check the forum first thing in the morning and mid afternoon so i can sort any queries if possible.
Post  Dave Saunders on Tue 02 Nov 2010, 7:45 pm
Many thanks again, I'm sure I'll get the hang of it.........eventually.
Dave
Dave Saunders
Number of posts : 6
Post  hughb on Thu 04 Nov 2010, 9:12 pm
I do not know if you have done this yet but I used Reeves smoke box paint as it is a mat look
Good luck and do tell how you get on
Hugh
