Presedential Candidate??
Page 9 of 10 • Share •
Page 9 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Re: Presedential Candidate??
A think of Beauty, you've done a fab job there!
ejparrott- Number of posts : 117
Had a good steam up today as the forecast was good and the kettle needed testing, this is part of the road run we went on, second gear first then me and Andy in top. Few bits and pieces getting ready for the coming year.
Indeed when you were going to post this one.
lynnr- Number of posts : 2919
Nice one kev looking good had a steam up myself today . Will try and put up some pics and video tomorrow.
chop- Number of posts : 77
I was tempted today as it was sunny. But the mercury is due to go into hiding again in the next few days.
I would go again tomorrow but need to make the gate wider so i can get the engine out.
Hi Kev,
Great video ,Is that the 4 note chime whistle you have fitted to your engine?
What do you think of it? I was thinking of getting one .
Kevster- Number of posts : 410
That is the 4 note whistle that comes from either Polly or Bruce engineering or one of the others, quite widely found I think, probably Barkers made or someone like that. Good thing about that is it screws straight into the existing valve, only needs a slight file where the base starts to cover the inlet in the valve base and restricts the steam. Needs quite a good pressure but does have a nicer sound on the ear than just a single whistle.
Going stir crazy now for a rally!!!
Been out and cleaned the Ifor Williams today
for the coming year, found a few bits I had forgotten about!!!!!
Thanks Kev,
I had seen it on the polly engineering website.
will be putting one on my engine too, may have to get a siren too,the neighbours might not like but I will!
Sirens are enormous fun...thats how I ended up with a my nickname!
My wife hates the siren and I cant get enough of it!! Broken the chain at the moment otherwise I would have used it on Saturday. Trying to locate a stronger but small link chain to replace it, does anyone know where I can find a small possibly welded link maybe stainless chain?? Been thinking about model boat supplies but dont know quality of chain.
Kev,
From what pressure is the 4 chime effective?
Good sound clip would be nice to hear?
Yes that would be good,
any chance Kev?
thanks
any chance Kev?
thanks
Kev,
I bought a stronger chain from LSM after breaking mine when using a 1/4" whistle valve from Heritage which has a much stronger spring to close the valve. Works really wel, is brass, has bigger links that are soldered. Page 38 on their catalogue. I went for 18swg size - priced all the same.
Rickster- Number of posts : 268
Is that the larger of the two whistles from Polly?
Did you use the valve supplied by STW or buy a new one?
How about the siren is that from R.A. Barker?
MrStationHouse- Number of posts : 313
Siren fro R A Barker is wonderful. Plumbs straight into the spare hole on the block with the supplied valve.
Lynnr wrote:Good sound clip would be nice to hear?
Clearly that will be another excuse to get up some steam
MrStationHouse wrote:Is that the larger of the two whistles from Polly?
Yes the larger of the two and yes straight into the STW valve but the base of the whistle needs a small slot filed in it to stop it covering the inlet hole in the valve.
highpressure wrote:I will certainly have another steam up, currently taking down a wall at homeLynnr wrote:Good sound clip would be nice to hear?
Thats what heavy haulage engines are for isn't it...taking down walls?????
Bit of housekeeping
Found a number of bolts going rusty mainly due to not painting them after fitting
and having run around at Portsmouhth with a lot of salt on the road due to the sub zero temperatures, so sorted some stainless bolts and have had them black nickel plated to replace the bolts on the rollers and the brake tubes and had the roller pins done, you can see the state of the brake tube bolts in the final picture. Also pictured here is the finished seat bracket with the addition of the brackets for the number plate, used some 5mm mild steel and welded it firmly in place. Looks like there will be a couple of events at the end of March and into April
Also was very disappointed to see the first big ring gear going rusty so elected the have that one nickel plated too, looks a bit bright at the moment but it will dull down quite quickly with use and oil, didnt do the others as they are more protected then the outer one and had no signs of rust on them and didnt want to dismantle the whole lot. Before anyone points it out Yes the washer and bolt for the brake lever need doing and will be added when I take The Colemans next batch to the platers, I have also found a couple of other bits that I missed too.
Did you forget something on the brake .
the coleman- Number of posts : 212
Got a clean pass yesterday, in the absolute pouring rain
Andy came up and we did the normal safety blowing off, gauge glass working, both water feeds working so all good. Was nice to get a steam fix but really wanted to drive around but the rain didnt let up until I was half way home when the sun broke through the clouds....typical!!
Weather was so poor and I had an evening arrangement which meant I couldnt get to the Wilton do, a shame as it looks like I missed out on real good show and I have a soft spot for scale fair models, would love to have the patience to build one. Now looking forward to Basingstoke on the 13 - 14 April regardless of the weather!! Having tested the gazebo in the most horrid conditions we can survive almost anything... should have a new organ to showcase which is currently nearing completion and the showmans can be seen and heard.
Just updated the 2 picture Gallery with the latest and probably final versions of the build. Hope to see some of you during the year.
highpressure wrote:Just updated the 2 picture Gallery with the latest and probably final versions of the build. Hope to see some of you during the year.
HAPPY BIRTHDAY KEVYN .
From the coleman.
Happy creation.
Hope you have a pleasant day.
Pictures look good.
Pictures look good.
Page 9 of 10
