Tyres and Masking tape
Page 1 of 1 • Share •
If you use Scotch masking tape medium adhesion.... make sure you do not leave it on for more than 2 days. Mine has stuck to the tyres like the proverbial to a blanket. Spent 3 hours last night on one wheel. Still not got it off yet.
lynnr- Number of posts: 1683
Registration date: 2010-08-06
Re: Tyres and Masking tape
I did that but i found if you just put a bit of pe-wipe on it will get the glue and tape of just fine. Oh and gives the rubber a nice shine
hudmut- Number of posts: 67
Registration date: 2010-07-05
making tape
I sympathise - I had exactly the same problem. I eventually go it off with aerosol label remover then acetone! Took me a while. I then changed over to low tack tape from Craftmaster which you can bend round to follow the shape of the wheel rim, despite it being plastic based . I used it on the edges of the tyres to stick newspaper to it.
I then wrapped the remainder of the tyre in newspaper and used normal masking tape to cover that. So only the edges were actually stuck with tape. Big improvement.
Rickster- Number of posts: 244
Registration date: 2010-02-19
I used panel wipe for the burrell which i highly recomend as it gets reed of all the grease and crap on the parts your about to paint i think this is the same stuff as pre-wipe, here is a link to the stuff on ebay :-
http://cgi.ebay.co.uk/5L-Can-Tetrosyl-Panel-Wipe-Pre-Paint-Wipe-Surface-Prep-/360292314085?pt=UK_Body_Shop_Supplies_Paint
Mark (even further north than the Mad lass of the north
tef 20- Number of posts: 140
Registration date: 2008-06-19
Wheely good time
Will use the advise on the Rear wheels when I get those kits.
Just waiting for kit 2 and 3 to arrive. Bit dis-appointed they should have been here today
they deffo left here yesterday. apparently it takes them two days to get to you
craig@STW- Number of posts: 995
Registration date: 2010-05-06
Brain fart
Hi Craig.
Sorry its me having a brain fart. Forgot to include the "next day" to get items dispatched. Yup it takes 2 days for next day delivery this far north of of Englandshire. What is the lead time to Shetland???
no worries, i can understand your urgency
im sure you won't be disappointed, once you get kits 1-3 together it starts to look like something
Is a "brain fart" a technicial term?? as I haven't come across that one
Vapor- Number of posts: 347
Location: Isle of Wight (2" Burrell & 5" Duchess ex MW)
Registration date: 2008-06-18
Removing glue left over on the wheel ,a tip I picked up when putting in car upholstery was to use a cloth with small amount of light oil on it really works to get glue off carpet and leather so could not see why it should not work on rubber. Tried it on my front wheels to remove a small amount of residual glue from the masking tape, and worked a treat.
IanL- Number of posts: 244
Registration date: 2011-07-25
Similar topics» Tyres and Masking tape
» Alternative to masking tape?
» Narrow masking tape source?
» HG Ex-S Gundam Digi-Camo
» Vulcanised Tyres and Powder Coating
Page 1 of 1
