2" Burrell Water Pump Pipe
Post  zzr prid on Thu 08 Jul 2010, 6:55 pm
What is the best way to put the bend in the water pump pipe Very Happy Very Happy
Thanks for the help
Stuart
zzr prid
Number of posts : 32
Re: 2" Burrell Water Pump Pipe
Post  andyc on Thu 08 Jul 2010, 7:16 pm
I bought a pair of mini pipe benders from Proops whilst at harrogate show. Worked a treat.
regards
Andy
andyc
Number of posts : 43
Post  hughb on Fri 09 Jul 2010, 10:42 pm
Yes that is the same as me
Good luck Very Happy
Post  LilyJack on Mon 12 Jul 2010, 4:21 pm
If you cant be arsed to buy a mini pipe bender you can always opt for this method which does work as long as you take it easy, use a bolt for your bend, two nice flat penny washers (service washers) and a lock nut, aint tellin you how to suck eggs but just wind the nut down the bolt with the two washers rattling, place the pipe between the washers and just gently pinch the nut up tight ish, when you bend the pipe, the washers will prevent "kinking", this is a tricky task so dont think it an easy get out, you have to watch the pipe carefully and adjust the nut accordingly so you can get the bend you want. Was just a trick I was taught during me apprenticeship..
LilyJack Cool
