Tow Bracket
Tow Bracket
Post  zzr prid on Mon 21 Jun 2010, 7:39 pm
I now have another problem Sad
The tow bracket BU20712 won't fit between the tender and the two tow straps BU20714 / 13. All the bolt holes in the side of the tender line up with the tow straps, but It looks like the tow brackets are to thick to fit between the cap.
What is my next step ?
( I also dont have any lagre tools only hand tools)
Stuart
zzr prid
Number of posts : 32
Re: Tow Bracket
Post  andyc on Mon 21 Jun 2010, 9:03 pm
Mine was like that but if you look at the inside angle of the tow brackets it is a rounded corner. All i did was file this corner square and it then fitted.
Hope this helps.
regards
Andy
andyc
Number of posts : 43
Re: Tow Bracket
Post  Big Al on Tue 22 Jun 2010, 7:16 am
Stuart
I had the same problem, It's all to do with where the bend is on the towing straps, they only have to be a fraction out and the tow bar wont fit. The thickness of the bracket was too thick only by a couple of tho or so, but it was enough. I measured up what the gap between the inside of the towing strap and back of the tender was and sent the tow bars back to STW and asked them to reduce the thickness to fit. They did it no problem and everything was sorted.
Alan
Big Al
Number of posts : 147
Re: Tow Bracket
Post  hughb on Wed 23 Jun 2010, 9:22 pm
I filed mine down as Andy says
Good luck
Re: Tow Bracket
Post  zzr prid on Thu 24 Jun 2010, 9:00 pm
Big Al wrote:Stuart
Alan
Hi all thanks for the help
I to have sent them to STW today and asked them to reduce the thickness.
Thanks all
Stuart
zzr prid
Re: Tow Bracket
