burrell 2" painting query
Post  Patman on Sat 12 Jun 2010, 5:33 pm
I have just started a Burrell 2" Traction Engine kit. Has anyone hand painted one? If so,what paints did you use? If not, hat other methods of painting were used? I would appreciate expert opinions.
Patman
Number of posts : 3
Registration date : 2010-06-12
PAINTING
Post  DavidH on Mon 14 Jun 2010, 10:58 am
I brush painted my 4" Burrell using Craftmaster paints. 1 coat primer (on steel parts),followed by 2 coats undercoat and 2 coats topcoat. Undercoats rubbed down with 600 or 800 paper used wet, and topcoats with 1000 or 1200 paper also wet. Followed by Farecla G3 Rubbing Compound and G10 Finishing Compound. This leaves a dullish shine which I, personally, find most acceptable. On brass of course use an etch primer first.
The paint finish even merited favourable comments in the modelling press !! See 'Engineering in Miniature' January 2010 p.225.
Best of luck,
DavidH
DavidH
Number of posts : 33
Registration date : 2008-11-14
PAINTING
Post  DavidH on Sun 20 Jun 2010, 8:04 am
I should have added that I used the best quality sable brushes. Expensive but worth it!
David
DavidH
Re: burrell 2" painting query
