Brakes Info new brake pads
Post  Skippy on Sun 03 Aug 2008, 9:32 am
I have found out that the original brake pads are of a performance grade and not general road use. I will be trying 2 new sets of standard pads over the next few weeks and see if this improves its braking. They are two grades harder then standard according to my local auto shop. So hopefully this will make the braking a bit better with a softer grade of shoe. Itís a cheep mode as they only cost around £14.00 a set.
Skippy
Number of posts : 12
View user profile http://www.veterantriumph.co.uk
Brake pads
Post  eric lindsay on Mon 04 Aug 2008, 12:47 pm
Hi Skippy
Can you please post maker and part number details. It seems a good mod to me.
eric lindsay
Number of posts : 5
pads
Post  Skippy on Tue 05 Aug 2008, 8:08 pm
For all you USA guy they are rear brake pads off Saab
900 96-98 or in the UK opel omega 2.5 and 3.0 90 onwards. The boxes of
pads I have are by APEC braking part number PAD 619
Skippy
Re: Brakes Info new brake pads
Post  WWayman on Fri 22 Aug 2008, 6:47 pm
The brake pads you mention do require slotting out the pin holes so they will fit.
I think there is slightly more stopping power, but they are probably not bedded in yet.
Bill Wayman
WWayman
Number of posts : 18
