insence to make him GO
Post  hughb on Sun 14 Mar 2010, 8:17 pm
I have been working on my engine at last now I am trying it on air....... Very Happy Cool Smile
OK done the fitting Laughing and put in the air Shocked {only a bit}all I got was 2 BIG leaks?????
Sad Sad Sad
So as there was no steam it was a case of sipt on the pipes ??????Then I had an thort Idea
Insence I have used this in caving to find the way on as you follw the smoke and smell.......Ok I like in in my shed some times .
this worked .. Smile First I found thet it was my blow down but it would not do up so I put in an "O"ring this now it is not blowing. The other one I found I still not get to ....
Also he dose want to turn over but a bit more puff is needed I guess .
This may help some of you to find the leaks without the help of steam ...But you may find that you will smell of insence and coff a bit .....
Good luck to one and all Razz
leaks
Post  Steve Traill on Sun 14 Mar 2010, 8:58 pm
If you don't have a nose like a bloodhound soapy water is a good alternative, just brush it on around any joints and look for bubbles.
Number of posts : 724
Re: insence to make him GO
Post  hughb on Sun 14 Mar 2010, 9:04 pm
Thanks Steve
I have been talking to some frends that go cave diving and thay look for air leaks with sope and water or grease ....
Post  LilyJack on Mon 15 Mar 2010, 11:30 am
Hiya ya big ole ugly bugga Very Happy
Not too sure on the "Grease" bit but most definitely soapy water is a grand way forwards for lookin for leaks, no matter how small, you'll see bubbles puffing out. Good luck on findin n sortin 'em out though chap..
LilyJack Cool
Post  hughb on Tue 16 Mar 2010, 9:04 pm
Thanks I have tryed this tonight ...Fary wash up soap works well big bubbles . Laughing
Pluss I am washing him as well Embarassed
