4" burrell running on air
Post  tompettitt on Wed 17 Feb 2010, 9:28 pm
hi from Tom in the S/E in sussex
with various holes plugged and valves turned off for steam injector and cylinder drains plugged ect.
engine runs well on compressed air at 60 psi. when run for an hour or so i need to reaset reverser and then decide where to put the slots.
leaks from safety valve from the spring tensioner bolt / nut from inside the chest. used copper washer and sealant. replaced nut less thickness of washer. will need to test and reset when in steam. while undone i lapped in slightly the valve seats. (just enough)
tried to lap in the globe valves on the steam chest but still leaking so need to do some more work there.
just need a few more bits like the cylinder drain cocks. sight glass mount on 2nd shaft and then twill be ready for the 1st steam up!!!
anyone else close? to share any niggles. like whats the extra hole for in the top of the block behind regulator.
Tom
(and still on target.) Very Happy
Last edited by tompettitt on Wed 17 Feb 2010, 9:31 pm; edited 1 time in total (Reason for editing : cylinder drains not got yet. plugged instead)
tompettitt
Number of posts: 14
Registration date: 2008-10-03
4" Burrell running on air
Post  DavidH on Thu 18 Feb 2010, 5:16 pm
Had mine ticking over on 10psi of air last October. Fed in at top of cylinder and blocked off holes through to boiler with threaded plugs.
Have just pressurised the boiler. Found M6 hole at bottom of cylinder for cladding (near blower take off) also needed blocking off.
Globe valves on steam head have a problem of which Steve is aware (5mm hole in valve body possibly not concentric with M12 threaded portion). Otherwise all OK although I've only got up to 40psi so far.
Have made my own bracket for top of gauge glass and also 'swinging arm' support for rear of ashpan. Basically now just waiting for the lubricator to light fire and steam up.
DavidH
Last edited by DavidH on Sat 20 Feb 2010, 5:03 pm; edited 1 time in total (Reason for editing : Removal of comment that this was in the wrong section.)
DavidH
Number of posts: 33
Registration date: 2008-11-14
Air leaks
Post  Steve Traill on Thu 18 Feb 2010, 8:04 pm
Don't worry about small leaks on air, I had a few when I first tried mine on air and was spraying soapy water at everything that might leak to check things out. When I actually lit a fire in the engine they all dissappeared! When it gets hot everything expands a little and it was nice & leak free.
Number of posts: 366
Registration date: 2008-06-29
Re: 4" burrell running on air
Post  Waterways on Thu 10 Jun 2010, 9:33 am
Running on air today globe valves leaking has anyone come up with a solution.
safety valve is leaking will this seal up when in steam?
Waterways
Number of posts: 93
Registration date: 2008-06-25
Post  RobertHenry on Thu 10 Jun 2010, 12:21 pm
When I run mine up on steam I did not have any leaks. If you do have a leak then you will have to let the boiler de-pressurise before tighting up any fittings. The reason is that if the fitting break as you are just nipping it up the you will have full pressure of steam coming out.
RobertHenry
Number of posts: 2
Registration date: 2010-05-12
AIR LEAKS
Post  DavidH on Thu 10 Jun 2010, 6:57 pm
Hi Waterways
Read what I wrote above (18/02/10) re globe valves leaking!!
I tried re-machining the seats but not very successfully. In the end I bored them out completely and pressed PTFE seats in. Now leak free and a lovely "soft" opening and closing feel. Not a solution for every one I know but Robert Barker will sell you a pair if you want.
The injector valve in particular MUST be leak free or the injector will get hot and fail to work.
My batch two engine now complete but haven't got round to steaming it yet due to gardening and trips away in our motorcaravan.
DavidH
DavidH
Number of posts: 33
Globe Valves
Post  Steam Traction World on Sat 12 Jun 2010, 4:16 pm
Hi Waterways
Contact us and we'll put a couple of new globe valve bodies in the post to you. We've remade a batch. The problem with the previous batch is that the drill doing the central hole wandered off centre.
Number of posts: 759
Registration date: 2008-06-18
Globe valves
Post  hharrop on Sat 12 Jun 2010, 9:33 pm
Have the same problem with the valves, both are not sealing so have not been able to try the injector yet, apart from that engine runs perfectly and will tickover quite happily on 5psi.
Martin H
hharrop
Number of posts: 7
Registration date: 2008-06-17
Running on air and finding the leaks!
Post  thehawk on Mon 18 Oct 2010, 7:12 pm
I've just got to the stage of running on compressed air and have been reasonably pleased with the result - except my compressor can't supply air fast enough for any longer periods of running. Noting the comments in previous posts, the globe valves seem to be fine (well, I replaced one some time back). There's a bit of air coming out of the safety valve spring, might just try running some loctite around it. But the real puzzler was the air blasting out around the cylinder front end. I checked the cylinder end cover, nope, checked the cylinder drain cocks, nope, checked the whistle and mounting, nope! The air seemed to becoming out around the cylinder cladding. So I removed the whistle and drain cocks to remove the cladding. My fear was that I had a leak between the cylinder and the foundation plate, dreading the thought of dismantling virtually the whole cylinder and engine parts just to re-foliac! However, due to the problems fitting the brass bands on the cylinder I had not fitted the short piece under the drain cocks and guess what, the screw hole for the brass strip under the front drain cock seems to have been drilled all the way into the blower drilling so air was blasting out of that!! I wonder if anyone else has experienced this - at least the solution is easy - stick a screw in the hole with a bit of sealant!
Paul
thehawk
Number of posts: 38
Registration date: 2008-06-22
Post  Waterways on Mon 18 Oct 2010, 11:26 pm
yes mine was the same. once the screw is in no leaks and once steamed the safety valve stopped leaking.
keith
Waterways
Number of posts: 93
Post  Steel Steam on Fri 22 Oct 2010, 6:11 pm
Yes - I had the same problem. To fix mine I abandoned the small brass strip and the little threaded bush that reduces the hole size used attach it and instead screwed in an M6 grub screw with sealant. Unless the small brass strips are cleaned very regularly they soon get blackened with dirty oil and cannot be seen so I do not notice that mine are missing.
David Steel.
Steel Steam
Number of posts: 20
Registration date: 2008-06-19
