Running On Gas
Re: Running On Gas
Post  LilyJack on Wed 10 Mar 2010, 6:12 pm
Quick update, made the manifold last night and bench tested the burner this afternoon.
Result : Burning way way to rich so will bore out the jets, replug them and drill using a 0.60mm drill instead of the 0.65mm, this SHOULD lean the mixture up slightly, the plus side is the flame from the burners is a nice consistant one albeit blue bottomed and yellow topped.
Will update again once the new jets are in place.
Regards...
LilyJack Cool
Re: Running On Gas
Post  hughb on Thu 11 Mar 2010, 6:32 pm
I am glad I can understand all this ??
Re: Running On Gas
Post  chrisnchrisroberts on Fri 12 Mar 2010, 7:52 am
As the vicar said, "be patient my son, all will be revealed in the end". Chris
chrisnchrisroberts
Number of posts : 123
Re: Running On Gas
Post  hughb on Fri 12 Mar 2010, 9:37 pm
chrisnchrisroberts wrote:As the vicar said, "be patient my son, all will be revealed in the end". Chris
That is not what the vicar said to the actress
Re: Running On Gas
