2"Burrell Smokebox tube / smokebox door ring
Page 1 of 2 1, 2  Next
Post  zzr prid on Sun 10 Jan 2010, 1:43 pm
I need some Help
I am having trouble fitting the smokebox door ring into the smokebox tube. I think the ring could over size.
But the ring dose fit the boiler end of the smokebox tube.
Has any one else had this problem ?
What would be the best way to get it to fit /sort the problem ?
zzr prid
Number of posts: 32
Registration date: 2009-01-29
Re: 2"Burrell Smokebox tube / smokebox door ring
Post  TonyT on Sun 10 Jan 2010, 1:58 pm
Hi Prid
have a look in your previous thread for help
TonyT
Number of posts: 119
Registration date: 2008-06-17
Post  zzr prid on Sun 10 Jan 2010, 2:11 pm
Hi Tony
And thanks again. It looks like it will need alot of rubbing down. Crying or Very sad
But at least I should be able to do that in work, as we use alot of flapper wheels. Very Happy
Prid
zzr prid
Number of posts: 32
Post  miller on Mon 11 Jan 2010, 9:32 am
just had a look at the parts in stock at STW and all ours seem to fit OK !!!!
it could be possible that your smoke box has been bent out of shape during our drilling op ??? it would have been held in a three jaw chuck and may have been warped.
we do have spares in stock and i'm sure Dean would be willing to replace your parts if you can't sort it Cool
Craig
Number of posts: 270
Registration date: 2008-06-16
Post  miller on Mon 11 Jan 2010, 9:43 am
just had a look at the drawings and both ends of the smokebox should be the same at 121mm +0.1 -0
the ring should be 121mm +0 -0.1
if the ends of your smokebox are different I guess this is the part thats at fault !!!
craig Cool
Post  zzr prid on Mon 11 Jan 2010, 7:44 pm
Thank for all your help.
There was a high spot on the smokebox tube.So after a quick rub the smokebox ring went in to place.
But i now have a new problem. I am 7 Rivet Bolts (BU20314 M3x11.5) Short.
I should have checked before I started. So have come to a stop again.
How would i go about getting another 7 Rivet Bolts ????
Stuart
zzr prid
Number of posts: 32
Post  miller on Mon 11 Jan 2010, 8:15 pm
phone us up at STW and talk to Isobel. tell her exactly what you need (part numbers are always helpful) and we will see if we have them in stock and get back to you Cool
Post  zzr prid on Mon 11 Jan 2010, 8:48 pm
miller wrote:phone us up at STW and talk to Isobel. tell her exactly what you need (part numbers are always helpful) and we will see if we have them in stock and get back to you Cool
Thanks for all your help. Have just sent Isobel an email with exactly what I need (and part numbers) . I hope this will be ok as I dont always have access to a phone during the day when at work.
Thank you
Stuart Very Happy Very Happy
zzr prid
Number of posts: 32
Post  northburrell on Tue 12 Jan 2010, 12:12 am
If your after some good spray on heat proof paint in a can for the smoke box and ash pan then a company called woodstock fires LTD stock calfire stove bright stove paint. good to over 600 deg c and comes in a nice satin black or matt black
I've just re-painted my smoke box with it as I brushed it at first.. Gives a very nice finish and costs a tenner.. there on ebay if you search for stove bright.. hope this helps..
Jo
northburrell
Number of posts: 181
Registration date: 2008-10-15
Post  hughb on Tue 12 Jan 2010, 8:10 pm
northburrell wrote:Hi,
Jo
Good to here you are doing ok ..AS for my ring I can not rember as it was so long ago . Question
Jo it sound like your paint is a lot better than mine as I first brushed it on that was bad in the end I sprayed it on as in my tred .
Good luck with your build
Hugh
Number of posts: 575
Registration date: 2009-03-13
Post  tef 20 on Tue 12 Jan 2010, 8:15 pm
Hugh i would rather not know about your ring lol!
Number of posts: 140
Registration date: 2008-06-19
Post  hughb on Tue 12 Jan 2010, 8:29 pm
tef 20 wrote:Hugh i would rather not know about your ring lol!
lol! lol! lol! geek albino
Post  zzr prid on Sat 16 Jan 2010, 6:33 pm
Hello
And a Big thank you to Isobel and Craig all there help with the rivets.
The rivets came today so spent most of the day working on the engine Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
Prid
zzr prid
Number of posts: 32
Post  northburrell on Mon 25 Jan 2010, 1:18 pm
Jo
Hugh
Hi Hugh,
Ye I hand painted my smokebox the first time round but wasn't really happy with the finish.. I have removed it from the boiler and stripped the paint off and taken the front ring out too. I'm about to re-spray it with the stove paint mentioned above..
northburrell
Post  hughb on Mon 25 Jan 2010, 1:22 pm
Hi JO
That is a long job all I did was to get out the tape and cover the bits up :~
As I was not going to undo all them rivets.
Good luck and can you post Cool
