burrell 4" Kit 22
burrell 4" Kit 22
Post  Waterways on Fri 08 Jan 2010, 10:16 am
On the gear changer bracket where should the M5 hole be for the grub screw to retain the shaft.
Keith
Waterways
Number of posts : 94
Re: burrell 4" Kit 22
Post  tef 20 on Fri 08 Jan 2010, 6:22 pm
Just put mine in the other day and it is on the right hand side under where the shaft goes into the gear change bracket i am sure there is a iso in the instructions? if you need any pictures of certain set up just ask.
Post  Waterways on Sat 09 Jan 2010, 12:28 am
There is no hole shown on the iso and mine is missing on the bracket so need to drill one.
Keith
Waterways
Post  tef 20 on Sat 09 Jan 2010, 5:50 pm
I wonder how they managed to leave out the hole maybe a one off!
Here is a picture of the grub screw although the pictures to very good it will give you an idea of what i was saying.
Post  Waterways on Sun 10 Jan 2010, 7:34 am
Thanks mark
now drilled an tapped
Keith
Waterways
Post  Steam Traction World on Tue 12 Jan 2010, 5:40 pm
Hi Guys,
Looks like we've made a cock up. The original batch were a fabrication which we changed to a lost wax casting to improve the appearance. In the process of the design change for the casting it looks like the M5 thread to lock the shaft with a grub screw was missed.
The following options are available:
1. Return the part and we will drill and tap it.
2. Drill and tap a hole to lock the shaft in place. (M4 or M5 or there equivalent will be fine)
3. Instead of tapping and locking with a grub screw. Loctite the shaft in position with a bearing grade loctite.
Sorry for the error.
Number of posts : 902
