2" Burrell Kit 22
2" Burrell Kit 22
Post  Agricola on Mon 12 Oct 2009, 11:58 am
Just received Kit 22 & checked contents. General;ly OK but my brake wheel handle seems to be a different thread from the brake wheel. Anyone else got this problem.
Agricola
Number of posts : 12
Re: 2" Burrell Kit 22
Post  Steam Traction World on Mon 12 Oct 2009, 12:18 pm
I have just checked the stock in packing and although the thread is a tight fit the handle did fit in the hand wheel. I did find that I had to grip the handle gently with a pair of pliers but it did wind on without much effort.
Number of posts : 902
Post  hughb on Mon 12 Oct 2009, 10:27 pm
Got mine as well .Yes the handle is a bit heard but used my good grip .
I do like the wood bet I mess it up Very Happy Surprised Shocked
Re:2"Burrell Kit 22
Post  Agricola on Tue 13 Oct 2009, 11:16 am
Thanks for your call. Tried what you suggested but no way was it going to have it. Grip on pliers was spoilng handle & there is no way it will screw full in. A replacement in due course appreciated.
Agricola
Post  TonyT on Tue 13 Oct 2009, 11:45 pm
Hi everone,
just 1 small problem I've spotted and spoken to Steve about this,on the gear change bracket (BU22201) there are 3 holes drilled and tapped for fitting to the rear spectacle plate and bearing housing,but only 1 hole in the spectacle plate.You will have to drill another hole in the spectacle plate for the 3rd fixing.I know this sounds like a pain,but it will have to be done to stop an fretting in the future,as the instuctions say,this is a high impact area so the more fixings,the better.I'm going to try this with the spectacle plate in place and then hope I don't have to remove the pressure gauge.
On a lghter note,whilst on the phone with Steve,I mentioned the subject of steaming our engines,and the response I got was go ahead but be careful and start lightly.I suppose make sure your boiler is filled with water,the tender has water and the pump is working.So I'm really tempted to give it a go at the weekend.What do you guys 'n' girls think?
Please let me know your thoughts on this,time to return to GH5.
cheer's Tony
PS Does anyone else play Guitar Hero on XBox 360,if you do send me a pm with your gamer tag and lets jam! Cool
TonyT
Number of posts : 134
Post  Agricola on Mon 19 Oct 2009, 9:45 pm
Thanks for replacement brake wheel & handle assembled. Cracking service. Do you want the old ones returning?
Agricola
Post  hughb on Tue 20 Oct 2009, 9:21 pm
Thanks for the heads up and I will have to have a nother look at the handle . As I am still no my splines but getting there Very Happy
Re. 2" Burrell Kit 22
Post  kwacker on Thu 22 Oct 2009, 1:16 pm
Hi Everyone,
Checked my kit last night and seem to have the same problem as Agricola. Tried to start my brake handle in the thread on the brake wheel and couldn't get it to wind on. Tried using pliers (and a bit of packing to protect the handle) - result? one chewed up handle with stripped threads!
Will have to phone STW and ask for a replacement.
Kwacker
kwacker
Number of posts : 1
Registration date : 2009-10-22
