Regulator set up
Regulator set up
Post  andyfletch on Mon 11 Feb 2019, 4:05 pm
Just working through Kit 13, Cylinder fittings.
I have a question about the regulator set up. Ive followed the instructions and drawings but find the Regulator valve, doesn't seem to be attached to anything. once the square nut is through the Regulator Rod there is a bit of a gap which means the Reg valve will lift up under pressure. I have found a small spring in the kit (BU41133) which looks like it goes under the nut which has a small inset to receive it.
The spring is not mentioned in instructions nor shown on the drawings. It attach a couple of photo's.
Have i set this up correctly ??
Andy
andyfletch
andyfletch
Number of posts : 20
Registration date : 2008-06-21
Re: Regulator set up
Post  Simon B on Mon 11 Feb 2019, 4:44 pm
On my kit the small spring goes between the square block and regulator 'puck'. The steam comes up the channel on the right hand side of your photographs and will fill the void above the regulator and below the safety valve, hence the regulator will be held down by the steam pressure, not by the spring pressure. Just make sure you lap the regulator puck to the steel plate below to ensure a flat surface or steam tight seal.
On my regulator the puck and steel plate stick together and if I haven't used the engine for a time I need to remove the safety valve to free up the regulator puck.
I hope the above helps?
Simon B
Simon B
Number of posts : 127
Post  andyfletch on Mon 11 Feb 2019, 4:56 pm
Thanks Simon
reassuring that I've got it right!
Andy
andyfletch
andyfletch
Post  the governer on Mon 11 Feb 2019, 9:00 pm
Make sure the bolt in the square block doesn't stick up too high, or it will foul on the bottom of the safeties.
the governer
the governer
Number of posts : 66
Post  andyfletch on Mon 11 Feb 2019, 9:07 pm
Thanks for the tip
andyfletch
andyfletch
Post  Will@STW on Tue 12 Feb 2019, 9:39 am
Hi Andy
The spring does go between the nut and the puck, But as was stated by someone else, the steam pressure will also hold the puck down. Your assembly does appear to be correct from what I can see on your photos. I will need to add something to the instructions about the spring.
Will@STW
_________________
If only we made a Marshall  Laughing
Will@STW
Will@STW
Number of posts : 11
Registration date : 2019-01-29
Post  Steve Traill on Tue 12 Feb 2019, 11:05 pm
It's best to use a stainless bolt & like said before make sure it doesn't stick up to high. STW used to supply a grub screw but it needs to be tight & grub screws have a habit of rounding off inside (especially with cheap allen keys). At least with a bolt one has something to grab hold of. Once you have determined the correct position I usually file a small flat on the spindle just to give the bolt a bit more to grip on.
Number of posts : 751
Post  andyfletch on Wed 13 Feb 2019, 8:23 am
thanks Steve
andyfletch
andyfletch
