Agricultural trailer
Post  Poderoso on Fri 01 Feb 2019, 6:47 pm
Help please
Not sure if I have any missing paperwork! but I don’t have anything that relates to the wooden chassis kit 4.
My drawing covering the timber chassis has no part numbers on it but more importantly no measurement to position the rear cross members w40239 to the chassis.
Gary
Poderoso
Number of posts : 6
Registration date : 2017-07-06
Re: Agricultural trailer
Post  Will@STW on Sat 02 Feb 2019, 1:10 am
Hi Gary
I will look into the problem when I get back into the office on Monday.
Will
_________________
If only we made a Marshall  Laughing
Will@STW
Will@STW
Number of posts : 11
Registration date : 2019-01-29
Post  sonick45 on Sat 02 Feb 2019, 9:42 am
I measured from the pdf I have of the plans which says its 1:10 ratio.  I changed this to 1:6 ratio to get the correct dimensions for the thickness of the timber at 5cm
I then measured the distance with the same ratio and got the measurement for how far in from the rear wheels are set.
Does this help with what you were asking?
Number of posts : 500
Agricultural wagon
Post  Poderoso on Sat 02 Feb 2019, 5:57 pm
Yes that’s exactly the measurement I was after.
Your comment got me thinking and on checking the drawings I see they are mostly on a scale of 1:10 so I will dig out the “Scale rule” for anything else.
Many thanks
Gary
Poderoso
Number of posts : 6
Post  sonick45 on Sat 02 Feb 2019, 7:02 pm
Yes I'm not sure the 1:10 or in some images 1:7 is correct. 1:6 gives all the correct measurements.on that image.
Post  Will@STW on Mon 04 Feb 2019, 2:58 pm
I have had a look at the drawings for the wagon, and the scale written on the drawings are not correct to the scale of the actual drawings. For those of you who need it the scales are as follows:
  • Sheet 8, 1:10 scale
  • Sheets 1, 4, 5, and 11, 1:7 scale
  • Sheets 2 & 3, 1:6 scale
  • Sheets 6 & 7, 1:5 scale
  • Sheet 9, 1:4 scale
  • Sheet 12, 1:2
  • and Sheet 10, 1:1.5
If any one needs to get new drawings then please let us know via email or phone call. I have also added a drawing with the dimensions refereed to above,  but it is worth noting that these dimensions are not critical, and it is down to you to make the final decision as to where the axles sit.
Will@STW
Will@STW
Will@STW
