Foden boiler on CNC
Foden boiler on CNC
Post  miller on Mon 10 Aug 2009, 9:29 pm
just a quick pic of the foden boiler on the CNC...
you can see that the boiler barrels are pre-machined before the boilers are welded up...
using these pre drilled holes, a cradle is mounted in the position of the cylinder. this then fits into a Jig that is bolted to the table, setting the boiler up nice and square. using the cradle as a reference point the mounting lugs are machined and drilled and everything comes out nice and accurate.
in many ways, this is done manually and takes a good bit of time, but then who wants to rush when you realise how much one boiler costs to make.
and they still need turning over for the other side to be done pale
Craig
Re: Foden boiler on CNC
Post  hughb on Wed 19 Aug 2009, 9:29 pm
Looking good well done guys Very Happy Cool
Post  miller on Mon 18 Jan 2010, 6:18 pm
next batch of foden and 4inch burrell boilers ready for pressure testing...
Post  Vapor on Tue 19 Jan 2010, 9:10 am
Nice photos keep em comming Craig, I can see my name on one of them boilers cheers
Foden Boilers??
Post  thehawk on Tue 19 Jan 2010, 7:17 pm
With respect to the last photo showing the boilers all connected up for pressure testing, they look remarkably like Burrell 4inch boilers - compare them with the other pictures?? Rolling Eyes
regards,
Paul
thehawk
Number of posts : 48
Foden Boilers??
Post  thehawk on Tue 19 Jan 2010, 7:22 pm
Hang on a minute I've just seen the Foden ones in the background - duh! I'll book an eye test!
Paul Embarassed
thehawk
