Weighshaft bracket
Weighshaft bracket
Post  NorfolkModelSteam on Sat 29 Dec 2018, 10:08 am
Iíve been looking at this part and not sure if itís correct and a few other people have seen it on my Facebook page and asked the same question.....should there be a hole as shown on the pic?
NorfolkModelSteam
Number of posts : 86
Re: Weighshaft bracket
Post  lynnr on Sat 29 Dec 2018, 10:39 am
No the bracket shown in the picture is correct. No hole in the lower casting area.
Number of posts : 2987
Post  Mark the spark on Sat 29 Dec 2018, 10:49 am
Hi Lynn
Where does the weight shaft go?
Number of posts : 251
Post  Mark the spark on Sat 29 Dec 2018, 10:56 am
I am going to stick my neck out here and say there should be a hole there for the weight shaft
Post  lynnr on Sat 29 Dec 2018, 3:20 pm
As far as I can remember there is another bracket to do that job
Post  bazzer on Sat 29 Dec 2018, 4:41 pm
Hi Norfolk,
If you look at the production guides for 13 April, it says that there will be no hole.
Barry
bazzer
Number of posts : 187
Post  Mark the spark on Sat 29 Dec 2018, 5:13 pm
ok I stand corrected
Just wondering why they went to the time and expense of machining the ends
Post  lynnr on Sat 29 Dec 2018, 5:30 pm
If I remember correct. It is the same casting as the Agi so cheaper to just use existing patterns and casting order and cut the bits off that are not needed.
Post  Simon C on Sat 29 Dec 2018, 6:04 pm
Mark the spark wrote:ok I stand corrected
The explanation for the machining is also in the April 13 text. this part of the bracket is the datum for the other machining work and on completion the hole is plugged Greg if you look at the right hand end of the boss you can just make out the plug.
Also looking at the pictures of the aggy it seems to be a direct drive to the governor without the use of the lay-shaft arrangement.
The lay shaft is required on the showman's to transfer the drive from the centre of the crank shaft to the right hand side of the engine to align it with the governor drive.
Simon C
Simon C
Number of posts : 83
Post  NorfolkModelSteam on Sat 29 Dec 2018, 8:05 pm
Thatís what I like about this forum - ask a question and an answer in hours!
NorfolkModelSteam
Post  craig@STW on Fri 04 Jan 2019, 7:35 pm
yes the above is correct. this is made from the exact same casting as the Agi and does not have a hole. However the hole is the first thing done to the casting and is used as the datum point for all the other operations. without this hole i was faced with the prospect of making a whole new set of machining jigs, and for this part they are not simple. I spoke to Steve and he agreed that the best way to do things would be to drill the hole and simply plug it up at the end.
I cant tell you why the central "tube" section of the casting is still there, all i know is that it matches the drawings i was given Laughing †is it there because its simply easier for US to make it from the same casting or... did we simply copy Burrell and did they make it from the same casting?? this i don't know.
but yes, same casting, 90% same machining operations, hole drilled and then plugged Cool
Number of posts : 1335
Post  craig@STW on Fri 04 Jan 2019, 7:44 pm
here is the casting in one of the jigs. you can see the pin through the central hole. this sets the position of the casting in the jig so all other operations are relative to the hole. very important on the Agi...
