Cylinder block material.
Post  9F on Wed 29 Aug 2018, 8:54 pm
Hi, can anyone tell me what the cylinder blocks are made from.
Rob.
9F
Number of posts : 7
Registration date : 2018-03-08
Post  hydro9 on Tue 11 Sep 2018, 6:33 pm
The block is cast iron and then machined. It sits on a machined steel saddle.
I'm curious to know why you ask the question.
Regards †Chris
hydro9
Number of posts : 19
Cylinder Block
Post  9F on Tue 11 Sep 2018, 6:41 pm
Hi, I asked the question because I thought it might be cast steel.
If you look at the photos of the production runs there is signs of coolant on the block, if it were cast iron, no coolant would be required.
Just interested.
Rob.
9F
Number of posts : 7
Post  hydro9 on Tue 11 Sep 2018, 7:01 pm
Interesting...... My 'cast iron' comment was a bit of an assumption.
If it is steel, as you suggest, then I'm really interested because I'd love to get the cylinder block permanently welded to the saddle. That would solve recurrent leakage issues from the joint between them, that my engine seems to suffer from. The Steamseal stuff only seems to last about a year.
Regards †Chris
hydro9
Cylinder Block
Post  9F on Tue 11 Sep 2018, 7:08 pm
Hi, if you inspect a newly machined surface on the block I cannot detect (see) the fine cast iron grain.
Also, if you rub it with white paper, I donít get the carbon deposit I would expect.
I have emailed STW but not had a reply yet.
Rob.
9F
Number of posts : 7
Re: Cylinder block material.
Post  craig@STW on Fri 14 Sep 2018, 3:23 pm
they are cast iron and yes, coolant is used. sometimes the castings are quite hard so coolant is used as a precaution and to wash the swarf away.
Number of posts : 1333
Cylinder Block
Post  9F on Fri 14 Sep 2018, 4:08 pm
Thanks for that information Craig, much appreciated.
Rob.
9F
Number of posts : 7
