Injector problem
Injector problem
Post  Tenbore on Thu 07 Jun 2018, 3:23 pm
Hi † When I start to get about 10 psi I get lots of water and steam gushing from the overflow on the injector turned every thing off but still keeps flowing end up having to dump fire any suggestions please as havenít been able to have a good steam up yet
Tenbore
Number of posts : 7
Registration date : 2017-09-04
Re: Injector problem
Post  Mark the spark on Thu 07 Jun 2018, 3:25 pm
Sounds like the clack valve is not sealing
Injector problem
Post  Tenbore on Thu 07 Jun 2018, 3:28 pm
Hi mark does that mean hitting the ball bearing in the clack valve
Tenbore
Number of posts : 7
Post  Mark the spark on Thu 07 Jun 2018, 4:04 pm
Yes
normally a tap with a punch on the top of the ball will do it
start with a light tap and if that does not work try a wee bit harder
Its best NOT to do it on the boiler but on a bench so your not putting pressure on the boiler
Post  bazzer on Thu 07 Jun 2018, 6:28 pm
Try closing the valve on the clack to see if that stops the steam, this will prove if it is a problem with the ball.
Barry
bazzer
bazzer
Number of posts : 190
Post  Capricorn1 on Thu 07 Jun 2018, 10:15 pm
Get hold of a few spare stainless steel balls from eBay, if you glue a ball to a short length of rubber hose or a piece of dowel you can lap the valve seat in with fine valve grinding paste or time saver lapping compound rather than resorting to the crude method of hitting it with a punch and hammer.... Make sure you give the boiler a good wash out as any SH1T will add to the difficulties of getting the clack to seal.
Capricorn1
Number of posts : 80
