Kit 10 bearing housings
Post  NorfolkModelSteam on Wed 25 Apr 2018, 9:55 pm
Quick question...I received kit 10 today and had a look at everything this evening; the right hand bearing housing doesnít fit, Iíve slackened off the bolts holding the spectacle plates but not enough movement to get it to fit, did anyone else have a problem?
Last edited by NorfolkModelSteam on Wed 25 Apr 2018, 10:20 pm; edited 1 time in total
NorfolkModelSteam
Number of posts : 89
Re: Kit 10 bearing housings
Post  LazySmurfer on Wed 25 Apr 2018, 10:06 pm
I had to removed about 1.5 to 2mm on my 4" Burrell to get mine to fit.
LazySmurfer
LazySmurfer
Number of posts : 74
Post  Simon C on Thu 26 Apr 2018, 6:42 am
Morning Greg
I am not at the same stage as you with this kit yet but I offered the housing to the horn plate last night and it fit like a glove. there is No room for paint on the spigot its that good a fit but will see what happens when the spectacle plate is fitted.
I will try it tonight and see, that's assuming that I get home at a reasonable hour.
Simon C
Simon C
Number of posts : 90
Post  lynnr on Thu 26 Apr 2018, 7:41 pm
Hi Norfork
Looks like your casting was not set correctly in the CNC and the hole pattern is offset.
Have a word with STW as I would guess a replacement is needed.
Number of posts : 3020
Post  Simon C on Thu 26 Apr 2018, 8:58 pm
well made it home at last and have just finished checking out "me bits" I will need to remove about half a mill from both edges of my bearing housing to allow the spectacle plates to be fitted.
Lynn if the casting fits the horn-plate and all the holes align without the spectacle plates fitted as mine do, then is the error not in the spectacle plate alignment? just a thought as grinding off is a sinch but grinding it back on now that's hard.
Simon C
Simon C
Post  NorfolkModelSteam on Sat 28 Apr 2018, 11:36 am
Thank you both! I heard back from Ian at STW and he has suggested as long as the holes line up on the horn plate and bearing housing itís ok to file down the edge of the bearing housing so thatís what Iíll be doing this weekend!
NorfolkModelSteam
Post  NorfolkModelSteam on Sun 29 Apr 2018, 10:20 pm
All done!! I think Iím going to hold off doing much more painting until I get the boiler.
NorfolkModelSteam
Post  bazzer on Mon 30 Apr 2018, 8:45 pm
If my memory serves me well, which I hasten to add these days its doesn't always, I had the same issue with my agri.
Filed a bit of the sides, works ok.
Barry
bazzer
bazzer
Number of posts : 190
