boiler check valve thread
Post  Kevster on Fri 09 Feb 2018, 3:35 pm
hi all,
im wanting to blank off the check valve threaded delivery holes in the boiler for the hydraulic test.
does anyone know the thread size please?
im betting Lynn will know.
thanks
Re: boiler check valve thread
Post  lynnr on Fri 09 Feb 2018, 5:03 pm
You got me at the moment. I do not currently have access to the drawings.
Number of posts : 2987
Post  Simon C on Fri 09 Feb 2018, 8:04 pm
1/4 bsp but if the hand valves don't pass then why break the clacks from the boiler?
The other way is to slide a shim between the boiler and the clack then re tighten the M6 studs.
Simon (a full roofer)
Simon C
Number of posts : 83
Post  Kevster on Fri 09 Feb 2018, 9:37 pm
Thanks Simon,
I get your point ,just wanted to take out any chance they might leak on the day,knowing my luck.
Post  lynnr on Fri 09 Feb 2018, 10:10 pm
You can perform a hydraulic test yourself without a pump. Blank the safety valves with the plate. Fill right up with water. Put in to full reverse gear and wind the flywheel forward. This will pump up the engine. Did this to a Dcc showman at Chipping last year for a in the field leak test.
Post  Kevster on Sat 10 Feb 2018, 9:34 am
I have a test pump so I might shut the valves ,pump it up and see what happens .
Post  Steve Traill on Sat 10 Feb 2018, 9:14 pm
For a belt & braces approach I've fitted a bolt to the safety valve blanking plate to hold down the regulator puck. Just hand tight is enough but sometimes without it it can let by & be a pain. Never known anyone have a problem with the clacks on a hydraulic test.
No doubt someone has though! but not down our way.
Number of posts : 743
Post  Kevster on Sun 11 Feb 2018, 8:33 am
I may be over thinking things then
Post  Ian on Mon 12 Feb 2018, 8:21 am
Kevster wrote:hi all,
thanks
That would be M12
Number of posts : 109
