Piston assembly
Piston assembly
Post  parador on Wed 18 Oct 2017, 5:44 pm
Some more advice please.
Query really on the piston rod bush-does this need some bearing grade 'locktite ' to keep it retained at the front of the 'stuffing box' or is it simply held in place by the gland packing? I can't see any harm in using some retaining fluid on the piston rod bush but what do you think please?
Martin
parador
Number of posts : 54
Re: Piston assembly
Post  sonick45 on Wed 18 Oct 2017, 6:48 pm
just push it in. its held in place with the packing.
Number of posts : 500
Re: Piston assembly
Post  Lynn@STW on Wed 18 Oct 2017, 9:04 pm
Just push it in. The stuffing and outer gland will hold it in. Also means it is easier to remove if fettling needed in the future.
Lynn@STW
Number of posts : 100
Re: Piston assembly
Post  parador on Wed 18 Oct 2017, 11:35 pm
Ok
Thanks again
Martin
Last edited by parador on Wed 18 Oct 2017, 11:36 pm; edited 1 time in total (Reason for editing : 2 replies)
parador
Re: Piston assembly
