Tender Water level indicator
Post  Phil Uridge on Thu Oct 12, 2017 7:11 am
Hi all,
After several steaming I feel the need for a way of knowing how much water is in the tender. I have run out several times and then panic sets in. I have looked on other forums and am looking and an idea from the 4" forum by using a car brake pipe fitting and a float on a rod. Has anyone fitted something similar to a 2" or how do you know how much water is in the tender?
Phil
Phil Uridge
Number of posts : 40
Registration date : 2015-05-03
Re: Tender Water level indicator
Post  Lynn@STW on Fri Oct 13, 2017 1:30 am
A Number of the 2" and 4" Agi owners have made the manstand inspection hatch easily removable. So a quick look in the tank is easy and also makes filling much quicker.
Lynn@STW
Number of posts : 100
Post  Phil Uridge on Fri Oct 13, 2017 2:15 am
Lynn,
That's a good idea, nice and simple.
Many thanks
Phil
Phil Uridge
