Issue with Chimney base casting
Post  Lynn@STW on Wed 11 Oct 2017, 8:14 pm
I have had a couple customers with chimney bases that do not have the hole drilled in it for the blower pipework.
Can you please check your chimney bases, preferably before fitting, to confirm that the base is drilled correctly.
Lynn@STW
Number of posts : 100
