Running engine on air
Post  Tenbore on Tue 26 Sep 2017, 6:21 pm
Hi all hope someone can help ,engine won't run on air ,pumped up to 20 then gradually up to 80 psi loosened escentricts,crank as much as I dare but just won't turn over ,she tries but just won't go any suggestions,help would be much appreciated
Tenbore
Number of posts : 5
Registration date : 2017-09-04
Re: Running engine on air
Post  Mike King on Tue 26 Sep 2017, 6:37 pm
Hi, I'm no expert, but have you checked that the piston gland isnt too tight?
Number of posts : 309
Post  Lynn@STW on Tue 26 Sep 2017, 6:54 pm
Small check list.
1. Does it turnover by hand fairly freely?
2. How is your timing?
Check the valve event.
3. Is your valve able to move on its spindle?
4. Glands too tight?
5. Hydraulic lock?
6. A mechanical interference?
7. Regulator puck correct, and moving?
8. Do you get anything out of the whistle?
9. Do you hear anything out the chimney?
Lynn@STW
Number of posts : 100
Post  Tenbore on Fri 29 Sep 2017, 1:57 pm
Thanks for the advice Lyn ,tried all what you suggested turns out to be the piston very tight in the bore, even with the glands slackened right off still tight ,don't know what can be done to resolve this one
Tenbore
Number of posts : 5
Post  Mike King on Fri 29 Sep 2017, 2:11 pm
Maybe need to file the ring gap?
Post  Lynn@STW on Fri 29 Sep 2017, 4:30 pm
Check the end gap of the rings. Otherwise the piston can be returned to have a skim off the diameter.
Lynn@STW
