Jimbos Windermere Kettle
Post  Jim the Shovel on Sun 10 Sep 2017, 10:31 pm
I really must stop getting side tracked and get on with building the engine.
This time I've made a windermere kettle.
As you will see it's all out of stainless. The tube is 80 x 200 high.
The top is an end stop for the next size pipe. Fitted a treat.
I'll just add that the stainless came from Germany. They seem to have a better selection of sizes than we do.
Getting an idea what it'll look like on the belly tank or box. The inspection hole is so I can get access to the fittings
inside. Think I should have made it a bit bigger. Will still hold enough for two mugs of tea.
View inside. Bent the heating coil. 6mm copper tube wrapped round de-icer can. Just the right size.
Finished kettle. The tap came from China 6. Well pleased with that, just the right size. I added a drain to the steam supply.
Didn't fancy water sitting in it when it was not in use.
Decided to put a chain on the lid. Didn't fancy leaving it in a field.
I took the supply off the water lifter supply and then via a valve through the motion guard to the other side.
Jim the Shovel
Number of posts : 102
Re: Jimbos Windermere Kettle
Post  Mark the spark on Mon 11 Sep 2017, 8:22 am
Nice neat work there
Number of posts : 244
Post  Lynn@STW on Mon 11 Sep 2017, 9:47 am
Looking very nice indeed.
It is amazing all the variations on the kettle and the plumbing methodology.
I wonder if Crystal would like one made for her. Hummmmmmm
Lynn@STW
Number of posts : 100
Post  Jim the Shovel on Mon 11 Sep 2017, 10:54 am
Go for it Lynn.
Bit of web searching for the materials and then find someone to do the welding.
But now with your contacts at STW shouldn't be difficult.
I think I saw somewhere on the forum that STW once produced a Windermere Kettle.
Might be good if they re-produced it as an accessory.
PS The DCC seat frame is coming along a treat.
Jim the Shovel
