Cylinder Block Studs
Post  LazySmurfer on Fri 25 Aug 2017, 3:09 pm
Fitting Cylinder Block Studs ok 2 nuts to tighten then up but do I use loctite ? I've heard some people say loctite them in & others say add grease so they can come out at a later date !
LazySmurfer
Number of posts : 74
Re: Cylinder Block Studs
Post  Lynn@STW on Fri 25 Aug 2017, 3:17 pm
Use a thread sealant on then to assist getting a steam tight fit.
Lynn@STW
Number of posts : 100
Post  LazySmurfer on Fri 25 Aug 2017, 3:27 pm
The steamseal ?
LazySmurfer
Post  Lynn@STW on Fri 25 Aug 2017, 3:39 pm
Oh
Is it the block to boiler or block to safety valves?
Lynn@STW
Post  LazySmurfer on Fri 25 Aug 2017, 3:51 pm
The hundreds of m6 studs into the cylinder block Smile
LazySmurfer
Post  Lynn@STW on Fri 25 Aug 2017, 4:05 pm
Little bit of thread lock then just to keep them put
Lynn@STW
Post  hydro9 on Fri 25 Aug 2017, 4:34 pm
Some of the holes are 'through holes' into the steam ways of the cylinder block. These definitely need a thread sealer. I found PTFE tape very successful. Others are 'blind holes' and sealing is pointless. Very useful to be able to remove some of these studs at a later date in order to fix problems with items that attach to the cylinder block. Space for these activities can often be very limited and stud removal makes things a lot easier. eg Exhaust pipe to chimney base when the joint to cylinder block starts to leak.
hydro9
Number of posts : 19
