Water Pump Pipes
Water Pump Pipes
Post  mariserve on Mon 31 Jul 2017, 5:17 pm
I have a small but irritating problem.
Of the two pipes provided, the WP Feed Pipe and the WP Bypass Pipe, one is too long and one too short.
Before I start cutting and soldering, am I missing something?
It would seem the pipes should be roughly the same length, about 90 cm. What I have are 87 and 97 cm. Even with an S bend the long one is too long to fit.
Any ideas please?
mariserve
Number of posts : 10
Registration date : 2016-05-11
Re: Water Pump Pipes
Post  Mike King on Mon 31 Jul 2017, 5:29 pm
I had exactly the same issue. I contacted Steve at STW, he asked me for the measurements required and sent me new pipes.
Number of posts : 311
Post  mariserve on Mon 31 Jul 2017, 6:09 pm
Thanks Mike, that solves the problem.
As I live in Florida, I'll try my soldering and not trouble the hard working STW boys.
Peter
mariserve
Post  Mike King on Mon 31 Jul 2017, 6:13 pm
Best of luck Peter, I hppe it all gors well.
Post  Lynn@STW on Tue 01 Aug 2017, 9:18 am
The gap between the threaded flanges is 90mm for both water pipes.
mariserve if you let me know. I can get new pipes sent.
Lynn@STW
Number of posts : 100
Post  Lynn@STW on Tue 01 Aug 2017, 12:57 pm
Hi mariserve
I have picked and packed replacement pipes. The will go out on the next parcel uplift.
Lynn@STW
Post  mariserve on Tue 01 Aug 2017, 9:01 pm
Great service, thanks Lynn.
Peter
mariserve
