Trouble with lubricator
Post  chas12154 on Sun 02 Jul 2017, 5:42 pm
Afternoon all, another problem! The cam in the lubricator, with the small grub screw in. I'm having problems keeping it tight on the shaft. I have tried thread lock, but it seems to come loose and the shafts rotates but the cam doesn't.
Any ideas on how to stop it coming loose. I don't really want to glue it in case I need to take it apart again.
Also, when I have manged to get it tight, how long does it take to get oil though? I have had it on a drill for 10 minutes but no oil.
Another question, when running on air, do you need water in the boiler?
Can anyone help?
Charlie
chas12154
Number of posts : 412
Re: Trouble with lubricator
Post  bazzer on Sun 02 Jul 2017, 7:05 pm
Hi Charlie,
Is threaded hole deep enough to put another grub screw on top to lock in.
Barry.
bazzer
bazzer
Number of posts : 190
Post  chas12154 on Mon 03 Jul 2017, 10:03 am
Hi Barry, that is a good idea, have to check and find out.
Thanks Charlie
chas12154
Post  chas12154 on Wed 05 Jul 2017, 6:26 pm
Hi all, manged to get grub screw to stay tight now. Now can't get the lubricator to pump the oil!
Anyone had the same problem and got any ideas?
Charlie
chas12154
Post  LiveSteam on Wed 05 Jul 2017, 6:44 pm
chas12154 wrote:Hi all, manged to get grub screw to stay tight now. Now can't get the lubricator to pump the oil!
Charlie
If the lubricator is the same, but smaller, as the 4" version is it adjusted correctly, is the front of the piston pulling back far enough to expose the fill hole of the cylinder ?
Number of posts : 533
Post  bazzer on Wed 05 Jul 2017, 6:57 pm
I found that machining grooves on the rod were preventing it from moving smoothly in the O rings, bit of a rub with very fine wet & dry sorted it out.
bazzer
bazzer
