Ptfe tape or paste
Ptfe tape or paste
Post  Chrs777 on Mon 29 May 2017, 7:12 am
HI. Just wanted your opinions on whether to use tape, or paste when fitting the cylinder block to the boiler on the threaded studs ?
Chrs777
Number of posts : 79
Re: Ptfe tape or paste
Post  Capricorn1 on Mon 29 May 2017, 8:31 am
Use graphite paste such as Foliac on the studs and the gasket, applied with a paintbrush. Spread it evenly on the boiler barrel then fit the gasket, apply another coat on top of the gasket then fit the cylinder block tightening the studs from the top outwards.
Capricorn1
Number of posts : 70
Post  Chrs777 on Mon 29 May 2017, 8:47 am
Thanks. I'm going to put liberal amounts of foliac on,
Just reading the instructions and it says to use ptfe,
I want to make sure that I get it right first time.
Chrs777
Post  LazySmurfer on Mon 29 May 2017, 9:26 am
LazySmurfer
Number of posts : 71
Post  Chrs777 on Mon 29 May 2017, 10:04 am
He is using paste. Seems there are some that use ptfe paste , some use tape, or no ptfe, just foliac.
In my instructions it says use tape. I think I will do that. Thanks for the replys.
Chrs777
ptfe tape or paste
Post  mick 100 on Sun 04 Jun 2017, 9:07 pm
hi there we used tape on ours and had no problems we finished our engine in 2015 all good if this helps .
mick 100
Number of posts : 97
Registration date : 2012-10-13
