Craftmaster varnish
Craftmaster varnish
Post  parador on Sat 13 May 2017, 11:27 pm
I've heard that on the final spray coat it is good to mix a little varnish with the gloss. Can anyone give me an idea what % of varnish to use with the enamel.
Martin
parador
Number of posts : 49
Re: Craftmaster varnish
Post  ejparrott on Mon 05 Jun 2017, 10:57 pm
Chris Vine used 50/50 on Bongo, can't remember his choice of paint though, will check the book
ejparrott
Number of posts : 117
Post  parador on Tue 06 Jun 2017, 10:30 pm
Thanks but I think it was Phoenix/Precision Paints. Not sure whether to add varnish or not.
parador
Post  sonick45 on Wed 07 Jun 2017, 5:58 pm
It all depends what finish your after.
Some use no Varnish
Some mix 50/50 or 70/40
Others such as myself wanted a flatter glass finish on the paint so have cut back the final coat of craftmaster back with 1000 or 1200 grit wet'n'dry and after lining have sealed with a coat of varnish.
leaves a very shiny very flat mirror finish.
Number of posts : 495
Post  parador on Wed 07 Jun 2017, 11:56 pm
Yes I am tempted to use fine wet and dry then varnish but am a little concerned that as I understand it the varnish needs to be renewed after a couple of years.
At present my plan is to varnish front and rear wheels- but not sure whether to just varnish over the lining or the whole thing.
Martin
parador
Post  sonick45 on Thu 08 Jun 2017, 8:24 am
I have not varnished the tender.
Most of which is hidden by other components.
I have varnished the wheels, side panels and boiler tins.
Post  parador on Fri 09 Jun 2017, 10:47 pm
Ok. what are the boiler tins? Hornplates?
Martin
parador
Post  ejparrott on Fri 16 Jun 2017, 11:09 am
Boiler tins are the cladding sheets
ejparrott
Bubbles
Post  parador on Sat 02 Sep 2017, 8:07 am
I have brushed the varnish but have found that I can't get rid of what seems like tiny bubbles all over the surface. The motion of brushing creates bubbles. The larger bubbles disappear when dry but the smaller ones are still there. I have tried a little of the pva additive but still bubbles. Anyone else had this problem and solved it?
Martin
parador
Post  Steve Traill on Sat 02 Sep 2017, 10:00 am
For final coating on brush work I use a 1" wide soft artists brush, one with very soft fine bristles, and lay the paint off in the direction you want usually vertically on an engine. I found the Purdy brushes that Craftmaster recommend good but are more use on full size engine/narrowboat. I would definitely apply clear varnish/lacquer to all the lining to protect it from the all the cleaning that will take place. I've seen it where the lining has been rubbed away from all the wiping down an engine needs so a couple of coats of lacquer really helps with this.
Number of posts : 743
Post  parador on Sat 02 Sep 2017, 3:26 pm
Thanks Steve
Any ideas about the bubbles?
parador
Post  Steve Traill on Sat 02 Sep 2017, 7:44 pm
With the right brush you can pull them out but the brush that made them won't help much. With the right brush you won't get bubbles!
Post  parador on Sun 03 Sep 2017, 8:01 am
Ok thanks. A new brush it is then.
parador
Post  sonick45 on Mon 04 Sep 2017, 8:39 am
As Steve said. Very soft square head artists brush. 1" max. Lay off slowly with only the weight of the brush pulling through the paint.
Post  elwood-59 on Mon 04 Sep 2017, 10:13 am
Sorry to jump in:
Any suggestions which brush? What do you use?
Thanks in advance
Elwood
elwood-59
Number of posts : 75
Post  Mike King on Mon 04 Sep 2017, 11:09 am
I used a few sets of the artists brushes fron The Works. They were cheap enought to buy a few sets. All I needed to do ead clean them in white spirit first before use, in case of loose bristles etc I obtained a brilliant finish. Mike
Number of posts : 312
Post  sonick45 on Mon 04 Sep 2017, 3:25 pm
I used this brush.
http://www.hobbycraft.co.uk/daler-rowney-graduate-flat-wash-brush-1/578243-1000
Washed well with detergent to soften the bristles and left to dry over night. The brush was then given a good clean with a tack cloth to get rid of any loose particles and bristles.
Got a mirror finish with heavy duty yaght varnish as a top coat.
Post  Kiwiconnection on Mon 04 Sep 2017, 10:49 pm
Hi all.
I find the Daler-Rowney System 3 Skyflow a great brush. Many different sizes and shapes, very soft and easy to keep clean with very little bristle shed. I have been using them for nearly 3 years now and they are still as new. Smile Smile Smile
Kiwiconnection
Number of posts : 131
Post  parador on Mon 04 Sep 2017, 11:58 pm
sonick45 wrote:I used this brush.
Coincidentally this is the exact brush I bought today. Used it tonight and no bubbles Laughing Laughing
The secret then seems to be a soft brush used very slowly.
Great result
Martin
parador
