Has anyone brought a Blower
Post  chas12154 on Thu 04 May 2017, 8:36 am
Hi all, I'll soon be steaming my engine. I'm after some information on where to buy a blower from. And what size I will need
Cheers Charlie
chas12154
Number of posts : 412
Re: Has anyone brought a Blower
Post  Ian on Thu 04 May 2017, 10:49 am
chas12154 wrote:Hi all, I'll soon be steaming my engine. I'm after some information on where to buy a blower from. And what size I will need
Cheers Charlie
You wont need a blower the 2" Burrell drafts really well, if your concerned just nip down to your local car exhaust supplier and grab a piece of discarded steel exhaust pipe about 50 cm long to pop in the top of the chimney, if you feel you simply must have a blower and the associated battery then look on the steam fittings website.
Number of posts : 104
Post  chas12154 on Thu 04 May 2017, 10:55 am
Thanks Ian for your reply. Will give it a go without one and see what happens. I only asked as I had seen other models with them and thought I would need one.
Charlie
chas12154
Post  LiveSteam on Thu 04 May 2017, 7:33 pm
I see many folks with blowers, from 2" 3" 4" and even 6" Shocked
Cant see any reason for one on 3" and above in honesty, although it does seem to make a lazy way of steaming Laughing a 2" will more than likely benifit from a blower, well maybe not benifit just take the skill of keeping the fire going in the early stages Wink
Our small 5" gauge loco we use to own was definately easier to to fire with a blower but with plenty of small wood and the occasional use of a fire lighter in the smoke box and an extension chimney she would light up quite happily without any mechanical blower at all.
Be very warey of over use and bringing it to temperature to quick if you're using a mechanical blower, I've seen two small engines suffer now in my short time at rallys with folks over egging electric blowers and bringing engines into steam in less than 20mins Neutral
Number of posts : 517
Post  Mark the spark on Thu 04 May 2017, 8:45 pm
locos tend to need a blower as there chimneys are a lot shorter and don't self draft very well
Number of posts : 226
Post  chas12154 on Sat 06 May 2017, 10:34 am
Thanks for all your replies. I think I'm going to wait and see how the engine steams before buying a blower. I think an extension chimney will be the way to go.
The next question is, how long the extension chimney needs to be?
chas12154
Post  Kevster on Sat 06 May 2017, 11:49 am
Maidstone engineering sell small blowers or you could make one yourself to save money.
Post  LiveSteam on Mon 08 May 2017, 8:37 pm
As long as you like really, I use about 5 feet on the 4" and on the little loco which I'd say is of similar scale to a 2" we had about 24" on it.
Post  chas12154 on Tue 09 May 2017, 10:20 am
Thanks Livesteam for your reply. Will get something and try it, see how I go.
Charlie
chas12154
